submariner
I know Bosch has a hybrid 1/2" impact wrench and 1/4" hex driver (USA # IDH182, Euro/Aus # GDX 18 V-EC). But does anyone make a hybrid 3/8" impact wrench and 1/4" hex driver? I don't mind 12v or 18v.
A 3/8" anvil is too small to encompass a 1/4" hex driver.
I'm sure it'll fit, why can't they use a stronger steel for the anvil![]()
Even with very strong steel, with it only being about 1/16 inch thick, would sheer under the torque.
It's not just about pure strength, it's being impacted hundreds of times a second. Even if you found this super alloy that could withstand the force and impacts, it would be very costly. The tool would be ridiculously expensive.From a simple search, there are materials >100x stronger than steel. Even the modest "ultra high strength steels" (already used in cars) are at least 5 times stronger than conventional steel. I see the 1/16 inch thick barrier being surmounted soon.
And again.. why would anyone buy it? Sales would be low
Would you rather buy a separate impact wrench AND impact driver when they're essentially the same tool?
No 1 reason is because 3/8" drive is used most often by DIYers and mechanics.
They are not the same tool, and yes I have both.
I forgot this is GJ
Of course everybody on here have both.
a hard no. i have that socket and will tell you why. first, that is not an impact rated socket. second, it is a great socket to put a bit in and leave but it ***** to take it out. like put the socket in a vice and pull the bit out with a vice-grip tight.
apex and others make an impact rated bit holder with a quick release. i have one and really don't recommend that either, it may work ok with a torx or hex bit but a phillips is bad and flat is worse. there is just too much runout when you start stacking parts and driving screws,
nothing beats a dedicated tool. i would take a cheap impact driver and impact wrench over a premium hybrid tool that did neither well.
