Is there an easy way to replace this valve? Plumbing question....
tominboise
This valve feeds my hose bibs. House was built in 1946 and this valve was put in then, I presume. I rebuilt it with new gaskets and seals about 18 years ago, but it is leaking again (won't shut off completely). I would prefer to replace with a ball valve if possible, but not sure how to approach it in this trapped location. If need be, I'll disassemble and rebuild again, but what say you?
Jim greengo
Behind my house
That's going to involve cutting/unscrewing a lot of pipe and installing a union someplace,or repiping in copper.
Probably easier to pull it apart and replace the washer in it.
T
tominboise
Rebuilding is a matter of finding a local Hardware or plumbing store with the correct gaskets and seals. Last time the lady at the local ACE hardware had all the parts and knew what I needed and where it was in the store. She is long gone, of course.
Walkers
Cave Creek Az
If you can rebuild it for another 18 years then do so. Without cutting everything apart you could cut the valve out use a sweat in ball valve and sweat X threaded adapters with short pieces of pipe to sweat in a ball valve. There is potential for a galvanic issue, but it would probably take 30 years to be a problem.
Meursault74
Southern California
T
tominboise
I will probably try to rebuild it again before I start cutting.
motorcycle79
wisconsin
If u want to replace it this is how I would do it. Shut all water off to house and drain best of ability. Sawzall pipe left of valve might have to cut it twice for enough space to unscrew pipe to both tees. Replace with Pex would be the easiest and fastest and would probably fit in the space you have. Otherwise replace with extra offset to make room for a union
T
tominboise
How hard would it be to get a PEX fitting to seal in the threads, of that upper Tee (the one feeding the hose bibs? Probably the fitting is quite corroded but maybe the thread sealers are thick enough to seal it. I realize I could screw a 3/4" PEX ball valve into that Tee, facing down, and then use PEX with a 90 and then into the other Tee on the supply side.
And why does 3/4" PEX seem so much smaller than 3/4" pipe?
rharman
SoCal
housewolf
East Texas
The pipe and fittings are probably full of sediment but the threads will probably look good when you back out the pipe. The wall thickness of the pex is significantly less than gal. The ID is same
73project
I would skip the big box/general hardware stores when sourcing plumbing parts such as these. I would head to your local plumbing store where the people that do it for a living shop. You will get someone that probably knows the manufacturer of that valve, and you'll stand a better chance of getting a quality replacement part.
Renegade1LI
long island ny
It’s only screw pipe, i would have to repipe it so it was a little neater, probably change to copper. If you want to keep the valve in that location remove as much threaded pipe as needed change to copper and use a slip coupling for your final connection. If you have access to a press tool even easier otherwise a few sweaty joints.
Bert_
NW Iowa
PEX is copper tube size. 3/4 Pex IS smaller than 3/4" iron pipe
DGersic
DeKalb, IL
Easiest answer: rebuild it in place.
Best answer: start at the meter. Cut out everything. Repipe the house in PEX, or copper.
