ultravonder
- Joined
- Jun 16, 2021
- Messages
- 38
Situation:
Rental home - 4 bedroom, 2 story townhome built in 2014, located in central FL. Home has central AC, dual zone (one thermostat upstairs, one thermostat downstairs). Air handler and thermostats are just about in the center of the home. First floor bedroom is 3 - 6 degrees warmer than the rest of the house on a consistent basis. The room has 1 AC vent and 1 return vent, both in the ceiling. The room has limited sun exposure (front covered porch/foliage cover/blackout curtains over windows) and on first floor concrete slab. Townhome is an end unit with sun exposure on 3 outer walls. AC vent in room is physically the furthest vent in the entire house from the air handler. The room also has a walk in closet and bathroom that also have AC vents, but they are physically closer to the air handler/feel cooler than the main room consistently.
Two tenants sleep in this room. I change air filters every 1 - 2 months and check the unit regularly (unit has a slot for 20x20x5 filters, but I use the slot for 20x20x1 to promote more airflow). All the vents in the house were opened and it was cooling very well (especially in the FL summer heat) in every other room/space. Tenants setup a cheap thermostat in the downstairs room and complained about a temp variance. Had an HVAC service call with the company who installed the unit when the home was built ($100) to check everything - house consistently set to 68F, temp reading 52F at the vents, cold air actively blowing out of everything. Room measured 71.8 degrees at furthest wall at 15:00 with sun. Blower fan speed already turned up a bit from factory setting in the air handler. Freon levels and pressure normal. Half-closed some of the other vents in the downstairs rooms to try to direct more airflow to the warmer bedroom. HVAC tech did not have the impression anything was really "wrong", but suggested a system re-balance if messing with vents didn't work.
I instructed the tenants to leave all the doors open to promote airflow, however, they are not always able to do this (personal preferences). I also instructed them to turn thermostat temp up in the upstairs. Apparently with leaving all doors open and other vents semi-closed, the room still got up to 73F-74F in the night with thermostat set to 68F, ceiling fan/oscillating fan on, all doors open.
From my standpoint, the AC works as designed. The temp variance is even considered "normal" given the conditions according to some research. I realize that the builder probably did not pay as much mind to laying out the ductwork accordingly with this room being furthest away from the system, so I'm wondering if it just comes down to poor design.
Questions:
Would paying $500 to re-balance the AC system really help this issue? Would a vent boost fan or smart thermostat even help? It really seems like the issue is isolated to the air duct that runs into this room - should I look into replacement? Or should I just tell the tenants to deal with it and get a portable AC unit if they can't handle 74 degrees at night? From a landlord's perspective, I'm hesitant to invest even more money into this small anomaly, however, if there is a definite option that would help the temp come down for a reasonable price tag, I would be open to investing in it given the tenant comfort complaints I keep getting. HOA does not allow for window units, and I'd rather not try to get a mini-split approved as it's another HVAC system I'd need to maintain.
Any input is appreciated, thank you for your time reading and responding!!
Questions:
Anyway, I made him do it. The place has been cool for the last two years.......
