Is there such thinbg as a quiter pancake air compressor
TeamTruett
Mid Hudson Valley NY
My old 6 gal Porter Cable pancake is very noisy. Asking Santa for a new compressor. Are there any that are quieter or is being loud the nature of the beast?
rsanter
visalia ca
The quietest air compressorsare the scroll type, they are the most expensive.
The loudest are the oil-less , they are the cheapest
fireball05
central PA
California Compressors are awesome. We have four of them in various sizes for various task. They are quiet and work great.
DieselNut88
Northern,IL
I have a direct drive piston compressor. It is a tool shop brand from menards. The same one under different brands can be found. Home Depot has them. It is fairly quiet. I replaced the factory air "filter" with a 6" diameter real filter from McMaster Carr. That reduced the noise a noticeable amount.
Voi
Western South Dakota
I have the California Air Tools 5.5 gallon. Got it for $139 & wish I had picked up a second one. Surprisingly quiet & lightweight.
I believe there are re-branded ones at both Lowes & Home Depot.
crazyjim30
The most quiet air compressor I've ever heard was the one used to supply the Pneumatics lab at school. I barely noticed when it was running. It was a Festo air compressor. Specced at 45 dB . Be prepared for sticker shock, though. It's a $1000 compressor.
Sent from my Pixel XL using Tapatalk
Firebrick43
West central Indiana
The makita Mac700 is much quieter than the traditional pancake. It's a small horizontal tank but not much bigger. However it is much heavier as it's an extremely well built unit with cast iron oil lubed pump, good fittings and copper lines. Good out put as well.
It's not silent however just quieter and a much lower pitch that the screaming demon pancakes.
Nearly silent is the California air tools. Long term durability is questionable as it's An oil less piston pump that relies on Teflon rings and special cylinder coatings. There is few free lunches in small portable air compressors.
Rsanters comment on oiless be the loudest is false as the California air tools and the festo mentioned by crazy Jim are oil less. I assume I meant a diaphragm compressor that also happen to be oiless but a completely different design.
Leaflessshadetree
Don't ask.
What are you using the compressor for and do you want to stick with the pancake style?
I have a Rolair JC10, it's very quiet and easier to carry than an pancake compressor I've seen.
My BIL has a small Senco, not as quiet as my Rolair, but not loud. It is very easy to carry (about the size of a lunch box).
Either one has kept up as I'm putting up trim. I sometimes had to wait on the Senco when doing some quick framing (I had everything cut).
jhelrey
MN
I have a Senco 1 gallon. I use mine for finishing nails, etc. I don't know what you are using yours for.
850xpeps
Pancake compressors are usually louder because they are fast recovery compressors. I have a 2 gallon makita horizontaol tank that I bought with a finish nailer. It’s quite but heavy as phuck.
ishiboo
Oshkosh, WI
Crazyjake8493
Upstate NY
Probably nothing quieter for pancake-style, but check out California Air Tools small models or the Senco PC1010. I've borrowed my dad's Porter Cable pancake and it's horrendously loud. I plan on getting myself a PC1010 after the holidays for trim work and what not in the house.
willf650
I have a cambell hausfield professional pancake that is an oiless and pretty quite for an oiless. It spins at 1760 rpm and is made in the USA. I don’t know if they are available anymore. I bought it for my father quite some time ago so they are probably made overseas if they are still made at all.
T
TeamTruett
Thanks for the many replies, education received! Getting a replacement does not have to be pancake style, just similar size and weight. Used for topping off tires, removing lug nuts, and assisting on 1 or 2 brake jobs a year.
kbs2244
Quiet means weight.
The main market for pancakes is construction where light weight means more then noise.
If you do not need to carry it around, go with a wheeled tank style with a separate motor and pump.
The pump will be low RPM, cast iron, and quieter than the high RPM, "all in one," aluminum, motor/pump style used on the construction type.
For the least noise, replace the inlet filter with a small (25 hp) engine muffler.
The inlet is where most of the noise comes from.
Citation
Indy
Quiet doesn't have to be heavy. My CAT 5510A is an aluminum tank compressor. It's no more powerful than one of those 6 gal porter cable units (and has less air, 5.5 gal @120psi vs 6 @ 150. However it's pump flows just as much and at 35lb is not any heavier.
Good for what the OP wants.
