If I was to hang the drywall in a room 8'2" high, I'd probably hang horizontally and put the 2 inch piece in the center between the sheet edges. I'd cut it from the edge of a few sheets if possible. Then it is still just one, admittedly a bit wider, seam to tape.
The last hanging I did was seamed vertical and part of the room was about 8'6". I put a short piece at the bottom and had a **** seam to tape. Not that hard and not easy to see if you have an issue down against the floor.
I wish the worst thing I've found in my house was a 2 inch piece of drywall behind the base molding. How about a wall with no insulation, a window with no framing around it and wiring soldered together and taped? Also a ceiling of a large room with effectively no insulation (it was installed between the joists (for a flat ceiling area) and had a ridge vent at the top).
