DWinTX
Hi All,
I live in the Colorado Rockies at 8400' of elevation. I have a detached garage that is 24' x 40' and has an open ceiling. The walls are 10' tall with a center ceiling height of 16'. It is insulated with R19 insulation in the walls and R31 in the ceiling. The walls are finished in OSB and the ceiling with metal roof panels. I want to heat the garage with a mini-split system. I will never use the A/C side, only the heat. It frequently gets in the teens and twenties here during the winter, however it will sometimes get to single digits for the lows.
I was looking at this:
www.pioneerminisplit.com
Do you think this will be sufficient for heating the shop? I will never use the A/C so I don't care about that. I'm not sure 24,000 BTUs is enough. I'm not particularly price-sensitive, but I don't want to throw away money either. ChatGTP recommended a Mitsubishi system that is $11,000. Not sure I want to spend THAT much.
Pioneer® Quantum Ultra™ 22,200 BTU 20 SEER2 230V Floor/Ceiling/Low-Wal
Summary High Efficiency Quantum Ultra Floor/Ceiling/Low-Wall Ductless Split Heat Pump System Cooling capacity: 22,200 BTU/H with 20.0 SEER2 / 11.7 EER2 efficiency Heating capacity: 24,400 BTU/H with 9.5 HSPF2 / 3.44 COP2 efficiency Voltage: 208/230V, 60Hz, 1Ph Floor/Ceiling/Low-Wall Mounted...
