Is this compressor any good?
AZDevils
came across this And wondering if it is any good? Looking for a home garage, my head is way ahead of my wallet on wants so looking used.
GeoBruin
You really haven't provided much information about what your intended use case is so it's hard to say whether it will be "good" for you or not. Also, without a price range, it's hard to tell you what you could expect to get within your range or whether the Kobalt pictured is worth the asking price. Anything else is pure speculation.
What you're looking at there is an 11 ish cfm 60 gallon compressor with an import motor and pump. Used, it's probably worth a few hundred dollars if it's in good shape. It will air up tires, blow off your workbench, and run small air tools for short bursts or larger air tools for really short bursts. It will be loud.
Rinspeed
NY
I have the same compressor and I've been quite happy with it. Mine says DeWalt on it but they are made by Sanborn. They are not loud at all and they will run a die grinder quite well. New they are around $650-700 now, I only paid $450 on black Friday three years ago from Tractor Supply. Like everything else they have jumped up in price.
