Is this going to be a problem
64auto
Started to lay my 3 course of block. Noticed the footer had crackes in it. It was poured last Wed. Is this common, or will it cause a problem? seem to be top layer cracks.
64auto
What reinforcing do you have in the footer? And was the soil below the footer compacted and stable?
The soil below the footer is very compacted, also used 2 layers of steel in footer.
PAToyota
South Central Pennsylvania, USA
Two layers? You mean top and bottom? If you have longitudinal and lateral rebar top and bottom and a stable sub-base, then it is likely just shrinkage cracks and nothing to worry about. The steel will hold things together.
