Is this joiner worth $75
mike93lx
Richmond, VA
What are you looking to run across it? That's quite small and you may be able to accomplish similar results with a sled on a table saw or in a thickness planer.
billconner
Thousand Islands NYS
Ohh! I missed it was missing guard! Thanks Cobbler. Think one could be fashioned of wood? I thought if I could hear it running I could tell if bearings, etc., were ok.
I have a thickness planer mike. Thought this would work better for edges, right? Working on some stairs - all rough sawn cherry - thought a joiner would help.
Agree slotwitch73. Does make it attractive, and heavy.
Aaron_W
I can't tell from a photo if that is a 4" or 6".
I have a 4" Delta made in the 1940s. They are pretty simple machines and since they made tons of them most parts are readily available new and used.
Several places offer replacement blades and helix cutter upgrade spindles.
As far as size, I see many recommending 8" and larger jointers but that is very much dependent on you.
4" is quite small but I just use it for trim pieces and such. It has been perfectly fine for my needs.
lilredex
Toronto
I have used a six inch for many years for my edging, think a four inch would have been enough.
Check the blades for nicks and roll it over by hand to check for bearing roughness. If there are nicks, you can sometimes move one blade over to correct.
mike93lx
Richmond, VA
For edge flattening, width matters a lot less than bed length, and that bed length isn't going to be conducive to large boards, if that is a factor
My Old Tools
Hamrick Lake, TX
That is a very solid old Delta jointer on a cream separator stand. The porkchop guard can be fabbed or found on the auction site or BOYD on OWWM. Plan bearings and knife sharpening.
niget2002
Josephine, TX
I have a small 4" one similar to that. It works ok for small projects. It doesn't work well for anything furniture size for me. Something with a longer bed length would work a lot better for most of my projects. I've gotten to where I do most of my jointing using a hand plane.
StillTooManyHobbies
Port Tobacco, MD
It *looks* like a 6". It needs a blade guard, which as said could be DIY'd. It might need bearings (easily found) , maybe a belt, can't tell if it needs a belt guard or if the motor needs help. If it runs, it is well worth the asking price IMHO.
jives
Central NY
I made a guard for my 6" CM, but I also found a small guard (4" jointer) at the local reuse that I thought I may try to modify. It would not work because the post to fit in the hole on the jointer was hexagonal, not round. Find a manual online and see what the guard looks like. If it has a hex post and hole I'm happy to give you the one I have.
johnre
Portland, OR
Rolling caster wheel base looks like it needs to be repaired, if you want to move the machine around much. Otherwise, just take it off.
Chip shute could be improved and covered so it could be attached to a separator and dust collector.
billconner
Seems simple to remove wooden dolly. Maybe build a tip jack.
Going to see and hopefully buy tomorrow. Besides running or at least spinning knives holder and testing motor if no belt, any thing else? I've usually bought new machines so kind of new to me to buy old - other than furniture that is.
Aaron_W
They are quite simple, almost everything is easy to fix or replace.
At that price I wouldn't expect it to be perfect, but also no serious issues. If a 6" I often see them in the $100-150 range. $75 with a nice stand is a good price in my area.
Cracked or damaged cast iron would be a hard no for me. Cast iron is not easily repaired.
billconner
Bought it. When I got there the motor would not run. Fuse, wire, who knows. He said it worked when he listed it and I'd judge by his house and shop he's honest. Quickly accepted $50. All the adjustments work and they're nice heavy cast cranks and stuff. spindle turned smooth and easily. (What is that part called - knives holder?)
Trying to get it to run played with two switches and a mon-contact tester. Was unfamiliar with the 2 switches but when holding tester in left hand I flipped switch with right and tester signaled!
micromind
Fernley, Nevada, about 30 miles east of Reno.
Two things come to mind about the 2 switches;
1) Dual voltage switch. One position is 120, the other is 240.
2) One switch to turn it on and the other is a substitute for the centrifugal start switch that has failed.
When it's energized, what does it do?
bubinga
Those bearings are easy!
billconner
That's the worst thing to happen..........
You'll need to unbolt it and look underneath it and see where the wires are connected.
It may very well be burnt up and need to be replaced.
I know but there is a fuse reset and the odd behavior of the tester makes me optimistic it's a simple electrical issue.
Thanks to everyone who posts on this. Very appreciated.
