Is this mold on the floor?
weatherby460
Southern WI
Morton pole shed, that is insulated in the walls (with plastic barrier) and blown in insulation in ceiling. What is the white stuff on the floor and what causes it? The one picture is after I swept. You can see the difference by the track on the snowmobile.
Fav Onefour
MN cold and hot
How do I stop it?
It's tough. Surface sealers alone, won't hold up. Penetrating sealers will be better but you need to do proper prep.
The correct method is moisture management. The efflorescence is mainly from water-water vapor, coming through the concrete. Normal method is vapor barrier before concrete.
How is your ground moisture around the building? I see foam. Were you getting water intrusion? I ask because that my indicate you have high water pressure against the pad if it's coming from outside. That water eventually soaks into the ground. It's possible to prevent some of the efflorescence by reducing ground moisture.
C-S-H
That might be efflorescence (calcium hydroxide) drawn to the surface by a condensation event. Your concrete mix is supposed to have a pozzolan (fly ash or slag) in it that reacts with the calcium hydroxide (free lime from the cement reaction). Using a pozzolan and moderate water/cement ratio produces a low permeability concrete slab, and stronger too. A silicate densifier will react with the calcium hydroxide near the concrete surface and is your best bet at this point for a partial fix if the white dust is indeed efflorescence.
Improved700
NE Wisconsin
Not mold. Looks like dust build up and as others have mentioned, could be efflorescence.
Question is... what sled under the cover?
gmcgeo
efflorescence = salts.
If your concrete is getting moisture it can be drying and leaving the deposits behind
