With the way the handle is on my air compressor my filter only fits horizontal and not vertical. Just wondering if that is okay for the filter, or do I need to figure out a different solution.
Isn't it better to have a filter that can separate out water, such as the one the OP has shown, to be placed away from the tank, and not right at the tank, due to the air cooling down as it moves thru the air lines?
When I first set up my air compressor in my garage I put a similar filter to the one the OP has shown right at the tank. In that location I never got any water in it, even though I knew there was moisture in the tank because it would come out when I turned the petcock on the bottom of the tank to drain it.
With the filter right at the tank, there was never water inside the filter, but I was always getting moisture coming out of any air tools I was using. So I knew there was moisture in the line as the air cooled the further away it got from the tank.
After awhile I ended up putting a 15 foot length of air hose directly off of the tank, and then put the filter on the end of the 15 foot hose. From there I set up a drop going down to a airline connection point and below that I put a shut off/drain valve.
Once I did that the moisture was accumulating in the filter like is should, and I was getting way less moisture coming out of my tools.
I don't know if what I did was right, but I know it is working now and pulling out a lot of the moisture that it was not doing before when the filter was at the tank.
Jim
Jim
