Spacecoastz
- Joined
- Dec 7, 2022
- Messages
- 50
Back in 2022 I purchased a 120v 3,500 running watts inverter generator for emergency back-up power. In over twenty years I’ve never had a power outage last more that a few days. I want all of my 120v circuits to be operational (such as lights, refrigerators, and tv). Prior to this I used a supplemental wire system that I installed during home construction, but that only powered a few special (normally dead) outlets, so bathroom and bedroom lights didn’t work, all normal 120v outlets were dead, and I had to run a few inside extension cords.
In order to feed the 30amp four-pin house inlet box, I have a 20" adapter cord that plugs into the inverter generator TT-30 outlet and converts it to a 4-pin twist-lock receptacle, which then will allow me to use a normal 120/240v cord and plug into that 30amp house inlet box. So, all power will be 120v single phase…to all circuits of the house.
Of course, I will turn off all 240v breakers prior to inverter generator usage, and I do have a breaker interlock on my exterior panel. The question I have is… is this safe? I do have a few “shared neutral” situations, but I know exactly where those are, and will avoid using them improperly. Is there any danger in this kind of set-up during a temporary outage? Is there something I’m not considering in this set-up? To date I have not had to use this set-up. Thanks
