Is this to code?
mnoeltne
Grantsville, UT
I replaced a light switch with an Intermec timer switch this past weekend. This is in a new home, just built this year.
First thing I found was incorrect labeling in the breaker box. OK, got my wife to watch the light upstairs while I flipped breakers. Solved.
Second was a stripped screw holding the faceplate on. Must have held down the button on a power screwdriver and just wore all the threads off it.
Then as I start looking to see which wire is the feed, and which goes to the fixture I see that the feed is a stripped section of wire, which then carries on over to the other switch in the box. See pic.
Isn't the correct way to bring a separate pigtail off the feed to each switch? I did that for my installation by just cutting the wire at that stripped section.
Oh, I almost forgot to mention, the ground wire was just sitting in the box not connected to anything. I hooked it up. I thought code required the ground to the green screw?
This was supposedly wired by licensed electricians.
Eriehunter
The hot wire being stripped that way is very commonly done by residential guys. Nothing technically "wrong" but I prefer pigtails.
The ground should be connected to green screw on the switch (and metal box if you have one), many times residential guys loop them from switch to switch. I also prefer pigtails.
grantw
Bay Area, CA
This is what make me want to handle my own re-wiring. I'm very concerned that paying a "pro" will result in cut corners like this. :(
The FIB
chicagoland
I would pigtail it and be done, that looks like a cheap way to save a wirenut
It's not really about saving the wire nut, this is a very common practice, in both residential and commercial, that has been used for a very long time in my neck of the woods. Fewer splices in a circuit make it less prone to future problems, it also takes up less space in the box
CGT80
IE, SoCal, USA
x2
I like the loop method as well. I also twist the wires with my lineman pliers and snip the end before installing the wire nut. I have repaired many electrical issues that resulted from a bad connection with a wire nut. People either get lazy when they make the connection or they don't want to untwist the wires if they make a change later.
It is always good to find out if your inspector has a method they prefer or demand, before doing the finish wiring. We had some who would let us know what they wanted, when they inspected the rough in.
As said above done all the time and no code that doesnt allow it.
Disconnected ground wire was a screw up IF the switches have a ground screw. Older switches did not have ground screws.
Zeke
And it's a plastic box.
I don't mind a loop in wiring but I've not perfected a method of stripping w/o pretty much nicking up the wire. I suppose a simple wire stripper set to the exact depth and a utility knife gently used will do the trick.
mnoeltne
Grantsville, UT
OK, well, it's good to hear that the loop in the feed wire is ok.
The ground wire was completely detached, both switches had unused green ground screws, and it is a plastic box. I guess I need to pop into a few more boxes to see how the ground is handled. I also need to take the time to map all the circuits since they totally screwed up the labeling in the breaker box.
It's just a bit disappointing given that this is new construction supposedly done by professionals.
Thanks for clearing things up!
6PTsocket
You can never tell who the contractor hired to do the work. It doesn't sound like a pro job. I would think that if you hire a licensed electricion, directly, you would get better work. Maybe I am just naiive. I recently replaced a switch that was jumpered to the adjacent switch. When I got it back together one switch was dead. The jumper had broken off the other switch and I know I didn't stress it. It probably was badly nicked when it was originally stripped. Stuff happens.
Norcal
Tract homes are built as cheap as they can get away with, I hesitate to say they are built to minimum code. Add apartments, & trailers( mobile / manufactured homes) to that list too.
