I just moved into a house, and it has a virgin floor. I'd like to put down a flooring, because I like to keep the garage neat and clean looking, even though I do some moderate work.
I had use Behr "1 Part Epoxy"
in another garage, and it was ****. Gasoline spills quickly lifted it, and it all wore away in front of my lathe from walking on the swarf.
My last house, I used SW Tile Clad in my last house, but I'm not sure about it. It was a two part epoxy, I thought it was supposed to be good. I had it tinted medium blue. I prepped the floor well (it was also virgin), but it was cold when I put it down. It was winter in Canada, but the garage is insulated and I had heaters going. I don't know what the actual slab temp was though. The air temp was probably 60-70. Anyway, I found that the epoxy marks really easy. Anything you drag across it leaves white marks. Not sure if it was the temp, the tinting, or just the way it is...
I like the idea of VCT for the look, and the cost and ease of install. Also because it's easy to put in a nice pattern. I can deal with having to use pads under jacks and stands. But I'm worried about a few other things:
I've heard that lowering a car off a jack and tear up a tile because of the tire scrubbing across the floor because of suspension geometry. Or how about turning the wheels with the car stationary? This left swirl marks in the Tile Clad epoxy floor.
And what about gas? I heard that ruins the tiles too? I don't have leaky cars, but occaisionally might spill a little while filing something up, or doing fuel system work.
I do have a welder, but it's a TIG, pretty clean, and I can deal with that problem.
I'm mostly concerned with lowering a car off stands. Or turning the wheels while stationary, and the effects of spilled fluids. Will this destroy the tiles?
The garage isn't a museum, but I like to keep it looking nice, and more importantly easy to keep it clean.
