Is your garage space "zoned"?
BlackLead
Biloxi, MS
I'm trying to get my head around the idea of all the multiple uses my garage has, but I'm having trouble making categories. As an extension of my home, it sees use as a workspace, storage, and sometimes even parking. I'm hoping that this will help me better organize the space and make more efficient use of it by dividing and assigning locations, and not just putting stuff on shelves. Has anyone done this that can give some pointers?
Steevo
43.49600, -112.04300
Do you mean "zones" for specific purposes, or to separate functions?
Such as: Your fire/spark/hot metal zone should be as far away as possible from your flammable material cabinet?
waggie
Upland, ca
put wheels or casters on everything. then roll out what you need when you need it. not all of us have the luxury of being able to separate "grinding area" and "welding area" and "machining area"
RVDan
North America
I have a parking zone and an everything else zone.
Nothing may ever be stored in the parking zone, last time I put something there temporarily it was six months before my car got into the garage again.
ChristopherLutz
Flower Mound, TX (DFW)
BlackLead - not yet...but, I have the concept in mind.
I only have one "man-door" and it goes to into the house/laundry room. We use the for the obvious..but, alsot to store bulky overflow household items such as paper towels (kitchen roll for those across the pond)
Anyway - that door is used "a bunch". The kids have bikes, balls, etc that they have in the garage so they are always playing with the car doors open and coming and going through the garage. If I had to guess, I'd bet our garage entry is used 8x the main front door.
So - when you first step out into the garage, I've got a section of gladiator garage wall that I'm using for mops, brooms, dust pans, etc. Next to that will be the "sports cabinet" I've just built.
This will hold golf clubs, raquets, balls, etc. The shelf on top will store odds and ends.
All of this will be seperate (as can be in a garage) from the work bench area. In an effort to try and keep things contained.
I'd like to have an area in my 3rd bay that can easily be used for wood work. Because that requires space...I will looking into putting workbenches on casters to allow for easy out of the way when I'm not using.
The post above re: wheels is pretty critical. I think you'll find two things:
1) you won't be able to anticipate the way you want to use things at first (without trying a few set-ups and,
2) your interests and needs will change.
Good luck.
bigdav160
Deep in the heart of Texas
My 42x26' garage has two distinct halves.
One half as 10' walls and an open ceiling for the lift. Corvettes and Z28 are parked there.
One corner has shelving for gasoline-oil and some yard tools. The other corner has beer fridge and fermenter. Shelving, tool boxes, workbench along the back wall.
The other half has an 8' ceiling with loft storage above. This is the wood/metal fabrication area. Everything is on mobile bases in case I need to park another vehicle over there, I can. Lumber storage on one wall. Cyclone dust collector in one corner and three tier shelving along one wall. The back wall has my fishing, camping stuff. It's directly above my welding table so I'm looking to relocate that stuff somewhere.
Garyk111
Hi,
I have a new garage to use my old tools in. Buying a Ford Ranger to take to Mexico and want to make sure I have the correct METRIC tools with me to make the long drive, from Boise, I'd to San Carlos, Son. MX.
BlackLead
Biloxi, MS
Good luck.
This is along the lines of what I'm talking about. On all these organization sites I look at, they talk about identifying and categorizing all the uses of the space, and my garage has enough that I get a bit overwhelmed. Did you use a process of some kind, like making a list and deciding what went where, or just jump in there and do it? If you made a list, can I steal it for a baseline?
bczygan
DETROIT! Arsenal of Scrappers
It is very smart to start your planning by thinking of the various uses it will be put to. You can further break things down by planning a flow for different processes. For instance, if you do woodworking you can plan for material storage near the door, then planer, jointer, vertical bandsaw, tablesaw, router etc.
Zoning might be between woodworking, assembly and finishing areas.
Also think about the balance between fixed and mobile items. Some things need fixed locations like a big compressor. Mobile items let you rearrange things to suit different needs, and can be a way to make a space do multiple duties, but require you to set up the shop before using it.
Workstations help make tasks easier to do. Create storage at each machine for all the items and accessories used with it.
Make a list of uses or functions. Make a list of existing and planned tools and storage devices (Cabinets etc.) and other things that will occupy the space. Make a drawing to scale of the proposed space and each item that will go in it. Cut out the items and move them around in the garage to see how they can be arranged.
Consider getting storage of seasonal and yard items and bikes into another structure like a shed or accessory building.
Consider expanding your work area with a combination of tools on wheels, and a large door that opens to an adjacent covered and paved space. During good weather you can roll tools out there or park cars out there to give more garage work space.
crewchief888
NW indiana
every year or so my garage goes through a transformation of sorts.
i move stuff around, seeing what works best for my 19x22.
i dont do much woodwork stuff in the garage, unless i have to, sawdust and sparks dont mix well.
:beer:
Zeke
You've identified 2 zones: storage and workspace. To me that suggests the cars and workspace will overlap. Go storage on the wall you would not want a workbench on. Build a workbench open underneath so that you can roll tools under that would normally be used in the "workspace."
Lots of guys build a nice bench all set up for a chop saw with support on both sides and a backstop for the work and movable stops and a tape. I would not do that unless I used that saw all the time and I mean all the time. I'd rather have an open un-dedicated bench. Roll out the saw, flip up some extensions and cut.
The key is to have flexibility and a place to tuck everything away so you can park in there or start a new project. Nothing like wanting to pull out the paint gear and start mixing on your table saw.
Or say you want to weld. Bring that gear out to the workspace away from storage and your regular workbench. When done, roll to where it lives.
