I ran copper pipe in my garage before I found this site and started to learn the right way to do things.
I ran my drops with a T straight down from the main top line, not the up and over which I gathered is "proper". I still put a drip leg at the bottom, and the hose is T'd to the side. Should I really go through the hassle of correcting it? I don't get any water out of the drip legs (from either one of the 3 drops) so I'm not sure if there's any advantage in changing the setup.
The compressor is a Quincy QT-5 with a home-made aftercooler. The output pipe to the tank is at ambient even if the pump runs for several minutes continuously. From the tank I have a coarse filter / water separator, the regulator, then a motorguard TP style filter. From there it rises up vertically to the main pipe then to the rest of the drops around the walls. It's just me, I only use one drop at a time.
I'm having a problem with moisture, especially on hot (90+F) days. It only comes out of the tool, the drip legs are dry. That's why I think individual "point of use" filters probably won't help any. Is my only other option a desiccant or refrigerated dryer? Desiccant at the beginning of the line should protect all the drops against moisture right?
I actually have a sharpe 3 stage desiccant system made for paint guns - I just hate the thought of using it because the desiccant stage runs the air through what looks to be a 1/4" tube that is even more restrictive because there is a screen at the end of it. I hate knowing I'll have to turn the regulator up to overcome this restriction and waste compressor output. I seriously doubt its 30cfm rating with the way its constructed. Unless I can find another one cheap or maybe a DIY desiccant container with bigger lines...
