Issues with pressure treated 4x4's for work benches
Varty Yo
Sask Canada
Anybody see any issues with using pressure treated 4x4 for a work bench build? I have access to alot of them for next to nothing. Ill be painting them once the benches are built before the steel tops go on them.
ace10
Rural NoVA
The price is right. Use em.
You may or may not have an issue with paint. You'll need to try it.
I replaced my four board fence this summer. The lowest board is PT, the rest are oak. Everything was painted with black agricultural fence paint about eight weeks after I was finished, and I swear the PT boards took the paint better than the oak. I didn't do the painting, but it was applied with brushes.
Kev442
Wi
Only problem is with PT sawdust indoors. Older drier PT is more of an issue than new wetter.
V
Varty Yo
Sask Canada
So got the benches built now time for 3/16 metal tops going on. Should i just slap the tops ontop of the 4x4 or shouls i put some plywood inder before? i have bunch of 1/2" im thinking of going down 1st.
PassnThru
Bowling Green KY
Shrinkage/warping after assembly.
I know I'm late to the party but this is the number one reason not to use pressure treated for any project that you care about. No reason for it to be used indoors and it's the most unpredictable wood you can work with.
If you have some pressure treated that is a few years old and is actually usable then go for it.
MOwens
Use galvanized hardware because the treatment they use will eat away at the uncoated hardware.
Dustball
Hudson, WI
Use decking joist tape to keep the steel from making contact with the wood and use pressure treated rated fasteners.
16again
Boynton Beach, FL.
I would put plywood under the metal top.
finn
The UP, God's country
Plain, uncoated fasteners will corrode when in contact with the newer PT wood. Aluminum is a no no too.
I think the proper fasteners are heavily galvanized or epoxy coated.
I would use the available posts, but find something more appropriate for the work surface.
tinmanwpk
Jacksonville
Absolutely use a subbase under your steel top. We fabricate countertops for various customers. Even our kitchen counters have a subbase.
Junkyard Jim
Foothills, CA
Definately put at least one layer of your 1/2 inch plywood under the metal. I used two layers of 3/4 and have never regretted it. I can throw an engine block on it and it wont dent. Also if you can, get your metal guy to bend it for you. I had a lip bent down in front that covers the support and a lip bent up in the back about four inches. Adds strength and keeps stuff from rolling off the back. I welded ends on it to so fluids can only run off the front.
dkroth
Rochester, New York
I suggest rounding the edges with a 1/4 round router bit. And then sand the whole thing a little to give it a more finished appearance, even if you're going to paint it.
V
Varty Yo
Sask Canada
Yes its going to be prebent by the steel shop 4" lip down the front and 4" backsplash.
I was always leaning towards of plywood under just for sound deadening.
While building this i realized my garge is 2" lower from from front to back lol.
