Issues with Radiant Tube Heaters?
Brconley
KC
I’m in the planning stages of a new shop. I thought I had settled on putting in radiant tube heaters mounted near the ceiling. However, the HVAC contractor I talked to was concerned that with 10 and 12 foot ceiling heights I would have issues potentially melting/damaging things.
Apparently he has seen this in the past, specifically mentioned roofs on ambulances in a garage. He only recommends radiant with really tall ceilings. Specs on some of the units I’ve looked at supposed work with ceilings as low as 8.
Has anyone run into this issue?
Buckgnarly
VT
My ceilings are 14 and my lift is in the middle so it's far enough away. I think my clearances were 4 feet, and even at 14 I was close in some spots.
burleyfarm
Northern Michigan
When they get old they will rain rust on things.
True.
Mine was hung at just under 9’. Anything near the head of the burner tube got HOT so I parked the car and truck further away (10 feet from the actual burner).
Bert_
NW Iowa
They are great when you have a 14' or better ceiling. There are some low intensity ones rated for lower ceiling heights, 9-10' I think.
I'd really like to put one in the garage next to my house but 9' height is pushing it.
It's not going to melt anything but probably isn't good for paint and plastic to be really close long term.
beatuptruck
Calgary, AB
I have 10 foot ceilings in my attached garage and have a 10' 40000BTU Calcana tube heater mounting in the top corner of the garage oposite the doors. The back of my truck w/service body is within 4' of the heater. The Aluminum Tool boxes on the truck get warm but not hot.
My last garage had forced air heat. The Tube heater is wayyyy better/quieter/no dust/garage doesnt cool off much when I open the door.
The low intensity models are rated for lower mounting heights typical in a residential garage.
badmotofing3r
Wyoming
My Caribe is mounted on an 8' ceiling. So far with the few times I've ran it, the intensity is not worry some to me. My Tacoma and Ford were reading temps on my heat gun of about 90* F while in operation. 1394b7c528fd38b73eafb5d08ceedd25.jpg
sundirect
Outside the United States of America
Radiant Tube heaters work by being fixed to the ceiling and targeting infrared radiant heats towards to floor by a reflector. If you were to imagine standing in front of a roaring log fire, or in direct sun light, you only feel the maximum benefit of the heat when you're directly in its path, as soon as you move away from the fire or out the sunlight you feel noticeably cooler. Radiant tube heating work along the same principle, the heats rays only travel in straight lines (like light) and are absorbed by cooler solid surfaces which they're aimed at rather than being aimlessly pumped into the air.
Radiant Tube heating can be incredibly cost effective because you're not wastefully heating a large warehouse or open plan building, you're just targeting a specific area which can have a positive impact on your business, not just from the savings you'll see in your heating bills but also in reducing your carbon foot print. In compliance with the Kyoto Protocol, the UK government is trying to ensure all UK businesses produce as little greenhouse gases as possible, which is why the climate change levy was introduced. The less harmful pollutants your business admits, the less tax you have to pay on them, in fact, if your business is serious about trying reduce it's carbon footprint, you may even be eligible for an Enhanced Capital Allowance or a Carbon Trust Loan to help cover the cost of the installation and maintenance of your radiant tube heaters.
The downside of radiant heaters is that they do only heat the area they've been targeted on, if you're after a heating system to heat a wider area you may have to consider another method such as propane heating, or a warm air blow heater.
ltrsm
I have a 30 x 40 x 11 shop with a Modine radiant heater. Mine is 30 feet along the long wall aimed at a 45 degree angle with the required backside spacing. It works great.
I have had to replace the regular outlet ducting about every 2-3 years due to rust-out and the last 10 foot section when it was 10 years old for the same reason. I am in Minnesota and my HVAC guy,said it was probably because of condensation from just warming it up when I am out there and not keeping it at a constant temperature. (40 degrees to 65)
The only other problem was that I had to replace the vacuum switch that made sure the blower was running before it fired up the burner.
Another advantage is it it totally enclosed - uses outside air and exhausts outside. There is no open flame like a house furnace that can ignite paint fumes.
