ITE Three Phase Panel Question
Norcal
Yes, sometimes when breakers with a higher fault current are desired, 480V, 480/277V, 277V, breakers are used, but buying replacement breakers will not be cheap. That really is the big downside.
rlitman
Long Island
When you say 240V, do you mean single or three phase? If you mean 120/208V 3-phase, or perhaps high leg 3-phase, then yeah, it should be fine, though as mentioned above, breakers will be overpriced for your needs, unless you can find a deal on ebay or the panel is already loaded.
930dreamer
Amarillo,TX and Stinnett,TX
I'm looking for a three phase panel, mine has all the breakers but two, 30a, (2) 15a, (1) 20a already.
He is running 240 V three phase high leg delta
