I've got big nuts.
NAYLOR
Nuff said.
<a href="http://s419.photobucket.com/albums/pp275/courtnaylor/?action=view&current=bignuts.jpg" target="_blank"><img src="http://i419.photobucket.com/albums/pp275/courtnaylor/bignuts.jpg" border="0" alt="Photobucket"></a>
N
NAYLOR
They are off of a pressure vessel that runs at 2500 psi. My dad picked them up for $1.50 from the refinery scrap yard.
I want to know what the torque specs are for these things.
bchee
Texas
I want to see the tools they use to tighten them...
me too
What I thought was interesting at first was the fine pitch of the threads. I would expect a fastener that large to be on a coarse thread bolt. I'm not an engineer, that's just my observation.
Makes sense though since it's from a pressure vessel.
autoace
Maine,USA
You could use those for trick anvils. They would also be good for knocking wheel bearings races out of rotors, and such. Looks like the center diameter is about right for clearance, when a rotor is placed on top.
chammyman
Glasgow, Scotland
me too
the finer the thread the far higher the clamping force is and less likely to back off.
justinmc
KCMO
I've got a fairly large screw that I have laying on a shelf in my office. However its nowhere near the size of those suckers! Wonder what "size" they actually are. Mark out a couple of lines on the floor and measure em up!
Panzer
Well if I remember right those nuts are similar in size as some hydraulic cylinders I have torn down but the most torque I put on those were in the 15,000ft lb range a little scary considering the machine we used was homemade.
N
NAYLOR
The bigger of the two is for a 4" diameter bolt with 7 threads per inch; you'll need a 6" wrench. The smaller will require a 4.25" wrench.
speed bump
Butte Montana
As far as threads they are fine because they are going onto like material bolts.
As far as a wrench I have a 36" pipe wrench that I know will do the little one and I think even goes to 6" so no problems there.
If I wasn't putting off Thermo II and INC lab right now I could even give you an idea of what they should be torqued to.
