I've ordered 20led 9000lumen high ceiling 100w lamps
Norcal
From the looks of them & the price they are not UL Listed or listed by any other NRTL, Nationally Recognized Testing Lab., the cordset on that floodlight shown is using idiotic European color codes. Price is low though.
Sneeze357
Was considerably cheaper than incandescent or cfl.
How so? CFLs of the same lumens would be considerably cheaper.
Examples:
http://www.1000bulbs.com/product/64212/FC105-S41OD.html
105W with 7150 lumens for $20.98.
http://www.1000bulbs.com/product/71818/FC180-S50.html
180W with 11,100 lumens for $50.51
Sure, it is slightly less efficient than LED, but those LEDs will burn out long before you see your money back. If you use T8s, T5s or metal halide, LEDs are not more efficient at all!
You could even mount the CFLs in a fixture like this and still spend significantly less money:
http://www.1000bulbs.com/product/54002/FIX-70039.html
You could also use a T5 fluorescent fixture like this:
http://www.homedepot.com/p/Lithonia...ture-TZR-2-54T5HO-MVOLT-1-4-GEB10PS/202516724
And get 20,000 lumens for $69.97. That is 92 lumens per watt, or more efficient than the quoted number for your LEDs!
Or the old standby, 400W metal halide:
http://www.1000bulbs.com/product/100602/TL-50116PSMH400MT.html
Good modern fixtures warm up pretty quick and give you 36,000 lumens for about $150 at the same efficiency as LED. They are still hard to beat if you have tall ceilings.
They are very bright and throw a square beam and might last forever without ballasts.
They have a ballast just like anything else. LEDs do not run from 120v AC.
LEDs are interesting but let's not make up facts.
gasaxeman
Hodag Country. Rhinelander,WI
I hope you have good luck.
We had a slew of Chinese made drivers fail in a retrofit job we did.
The owner purchased the fixtures to replace 400w MH highbays.
He is not too happy with the result.
On the other hand I have had good results with the RAB units.
Hope it works out . Would like to see it all lit up.
volleyball
NY, not NYC
My local supply house had a bunch of similar fixture on their clearance shelf.
Is it common knowledge here to mount LED's with the electronics higher than the diode?
Opposite of CFL's.
Gasaxeman, hope you could salvage those defective lights. Fix them and put them in your place.
jeff000
Don't want those ohms leaking the wrong direction eh?
I have never heard that before, nor does it make even a little bit of sense. You do want to mount the driver as close to the diode as possible though.
I'd like to see the link though.
And for what it's worth, just because it comes out of China does not mean it is junk, some really high end stuff comes out of china and no one says anything about it, just have to watch. I install lots of LED, and have used Canadian, American, Chinese, and Mexican versions of the same lights, and visually I can't really tell them apart, but the Chinese ones are the ones I have had the least problems with. And the American ones are the worst.
volleyball
NY, not NYC
Ohms don't leak, they slow down the leak, everyone knows that.
It does make perfect sense though to do it as I posted.
Sneeze357
I pulled the link I posted because I was unaware that led experimentation might not be the thing to discuss here.
LEDs are most certainly something to discuss here. Anybody tries to discuss it with you, you post another made up fact an then run away. Sorry if I don't like people spreading misinformation.
gasaxeman
Opposite of CFL's.
I got one.
Working ok nice over my weld/catch all table
The other one is an old RLM I reworked and am using a CFL in it. Just a test at this point
