How did you locate your J-Bolts?
I'm having a new slab poured later this week; the contractor recommended using stringline as a guide. Anyone used any other techniques?
Thanks,
Ed
My building required 24 J-bolts in a particular pattern in order to support the posts. The concrete contractor used 1/2 plywood to make locaters for the bolts. Look thru my garage build thread; there are a few photos there.
Mike
Mike
I'd use stringline - maybe set your nails a day or two in advance so you're not trying to race time with the concrete setting up.
I'd also do the layout of each bolt location directly on the concrete form a day or so in advance - maybe spraypaint each spot so it stands out.
When the mud starts flowin, you want to have to do as little layout and thinking as possible. Concentrate your efforts on pour day to making sure everything is pitched the way you want it to go and doesn't have low spots where water will puddle.
I have wondered about this before... can you drill the sill plate and assemble the J hooks on the board ahead of time? Then, right after the concrete is pored, you set the sill on top and settle the J hooks into the concrete? This way the hooks are lined up with the board. I would think you would want to put plastic around the board so that you could take it back off after the hooks are set to put your seal on. You would not have a way to level off the concrete that the j hooks flush out, but that should be a known amount per hook.
A good way to set j bolts is to pour and consolidate the concrete. Then finish the top smooth and wet set the j bolts. Come back after it dries and snap your square string lines. Set the sill against the jbolts and mark the center lines. Then come in with a block of wood against the string line to mark the other center line. Set the seal and drop the sill plate over the jbolts.
What do you mean when you say "set the seal"? Am I missing something?
You want to put a foam or self adhesive rubber seal between the concrete and the bottom plate. Without the seal, there will be irregular gaps between the two which will create drafts in winter.
Another option is to caulk the inside and outside of the joint between the two. If you go this route, wait until the roof is on so you aren't holding any rain water on the slab with the plates.
Dow Foam Sill Seal
Like Junkman said, setting rods in epoxy is a great way to go, or, like I just did this summer on a big gazebo, you could use the Simpson Strong Tie "Titan" anchor bolts. They sell them in pairs at Lowes, and they are the galvanized version, so okay for treated wood sill plates. I love the things, and they use standard size masonry bits for the holes. You use an impact wrench to drive them in.
Why try to locate j bolts when you can finish the concrete easier without them, and take your time and put them where you want them after the fact.
