Jack Hydraulic Unit Identification and Rebuild
ktr32
Very first post to the forum.
I picked up a used Lincoln G9715 2TON Jack on craigslist, with pump problems and definitely in need of a rebuild, but need some help identifying the Hydraulic Unit to purchase a rebuild kit.
From research and comparing pictures, i think it is a 93642 type hydraulic jack unit and was built post 2000.
I already reviewed the following forum threads 1, 2 and 3.
I attached a few pictures of the hydraulic unit, also what size socket is need to remove the ram nut. I know I will need to purchase a piston pump assembly, but can I rebuild what I have.
Any advice and feedback would be great appreciated.
Thanks
ktr
Hiball
Missery
Its a 69715, Uses the Same Kit as a 93652, if you call the Number in my Signature you will need kit 1038.
