Jack ID - Help Needed!
Crude56
Hello everyone. Some help please. I have had this jack for over 40 years and it is in need of repair.
I can't remember the brand or model anymore, so if anyone could ID this for me that would be great!
Crude
Hiball
Missery
I'll answer here versus via the email you sent.
It's a Walker, it could either be a 757/767, the frame appears to be smaller than the 867, but the seal kits generally cover all series. It does appear that someone has added either a newer reservoir or drilled and tapped a vent, the original fill/vent is the Hex on the block.
C
Crude56
Thanks, I was wondering what that Hex was for ... so the seal kits for a 767 or 867 will work?
Hiball
Missery
Should, unless someone has updated the tank nut to a newer version, or updated the Ram. Oem would utilize packing on the tank nut and a leather piston seal on the Ram, versus a quad ring and poly ucup. It's always best to verify internal condition prior to buying a kit, especially on a Jack this old.
Good luck
