Jack ID
Ledman_70
hey guys, can anybody ID this long chasis jack? I picked it up last week off CL for $75. It needs seals at least because it bleeds off. Data plate is worn smooth. Thanks
Jeff
L
Ledman_70
And another. It won't let me post them together.
squeekers568
There's normal numbers stamped on it some where
Sent from my SAMSUNG-SM-G750A using Tapatalk
Hiball
Missery
Yep, Weaver. It appears to be a 4 ton based off the pictures, but there should be some stamping on the hydraulic unit itself, back near the release area. When you need parts, Hard or Soft.. Castle equipment is the authority.
Wa-72 is 2 ton
Wa-73 is 4 ton
vertguy
SE WI
I am in the process of restoring a 2 ton Weaver in this thread. The 2nd picture shows the model stamping on the top of the ram housing that Hiball referenced. Good luck!
L
Ledman_70
Thanks for the info guys. i looked at it closer last night and found the WA73 on top, so when Im ready to restore it, I will contact cassel, thanks
Jeff
