MikeMalibu
- Joined
- Mar 21, 2007
- Messages
- 10
I’d like to set the frame of my ‘49 Plymouth level for some restoration/modification work. The width of the frame (center to center) is about the same as the distance between the runways on my 4 post lift, so not enough runway width under the frame rails for jack stands. I have a bridge jack and jack tray that I can use for lifting. Appreciate suggestions on methods to support the frame rails. Thought about using 4x4 lumber or rectangular steel tubing across the frame supported by jack stands on the jack tray - doesn’t sound safe unless welded in place? Also thought of using 0.125 or 0.250” wall thickness rectangular tubing across the runways to support the jack stands, like 12”x 2” or 12” x 4” - too heavy? I’ve seen this method used on YouTube but can tell about wood / steel / dimensions. Thanks for your suggestions.
