Jack stands - ok to use after a roll off?
pendragon1998
NE Georgia
I was replacing a starter today and it about wore me out, with temps near 90, two broken bolts, one broken drill bit, and a very hard to access bolt. When I got done, I buttoned it all up and hopped in to test start it. Then, like an idiot, I backed it up, completely forgetting I was on jackstands. Well, I rolled off the stands, there was a loud clattering to remind me, and the stands look fine, except for a little scuffing on the feet. No cracks that I can see. Is there any reason to lose trust in these stands in the future (i.e., could rolling off of them make them more prone to fail next time they are used)? I am already not crazy about them, but they have always worked for me (made in china craftsman high lift 3 ton SUV jack stands).
Davefr
OR
That's a tough call.
If they're the modern heavy duty style and look perfect then I'd probably keep them. But that's only if you're following safe working procedures like ensuring redundant support. (ie never a single point of failure!!)
If they're the old style then it's probably best to upgrade.
Empty Pockets
Rural New York
If you rolled off of them, regardless of how they look, I'd replace them. A couple of jack stands are always cheaper than a hospital bill (and safer too)
PureLeaf
I can't offer any advice as to whether they're now considered dangerous or not. But if you decide to buy some new ones, and want to go the cheap route. Craftsman is having a sale on these craftsman professional 4 ton set for 22.99.
http://www.sears.com/craftsman-prof...D=1225267&AID=11042411&sid=IAx20050830x000545
Another alternative: I just bought some US Jack ones and posted photos of them in the new tool arrivals. 150 bucks for 6 ton per stand rated jacks.
full
CutterFarms
Kentucky
When the ground gave way under my truck it slightly warped a set of my stands and I replaced them before going back under it. I would never risk it as cheap as stands are. Imo
royesses
Save them for light duty stuff like keeping a transmission up while changing its mount. Get new good ones. I'd not trust them again. Just my opinion. A life is worth more than anything in the world.
DMAR
full
Those US Jack stands are real nice. That's also a good deal on the Craftsman....
Although I think you're probably fine with the stands that got knocked over (if they check out OK) for that price, I'd buy these Craftsman stands and have some piece of mind. Or, spend the dough, and get a nice set... I have a couple of sets of Hein Warner, no complaints..
mrvm
PA
If you decide to repurpose them for light-duty use rattle can them an specific color to remind you what they have been repurposed for.
blackwire
Also good for supporting an extension while working on a tight fastener. Like crankshaft bolts, lug nuts etc.
AmishFury
full
you say per stand but the sheet in your photo clearly states per pair
PureLeaf
MikeF2316
Thornhill, ON
Test them. If you use 2 stands to hold up one end of your vehicle, jack it up and put just 1 in the center. If it handles that, you're good to go.
If it doesn't, then it will be in a condition to remind you not to use it again. :lol_hitti
Warrenator
Newberg, OR
Inspect them. Metal isn't magic, it is a strong yet malleable material. It is has been damaged there will be signs such as bending, cracking, broken welds. Grab the various parts and see if you can twist them. Look at the paint to see where any impacts were. Use a magnifying glass to look at the welds and stressed areas.
I bet they are fine.
Jacobson
It's going to be in the back of your mind as you use them the next time.
pescados666
South Houston, Texas
928'er
Wine Country, CA
As they say, "buy a cheap helmet if you have a cheap head."
Your jack stands are past their "sell by date." Recycle them.
2oolhound
BC Canada
You could always jack up a really big truck, bus etc. and see if they support that ok. Then you'd feel safer about using them on a smaller vehicle.
nikerret
Kansas
I wouldn't have considered not using them, if they appeared okay. Perhaps, I should... After reading the replies, including the most cogent point: cheap to replace, I would get new and use the rolloff one for under the rear of the trailer, when I load the tractor.
