Slycox
So I've been using Harbor freight jack stands for a while never thought anything of it till I joined here and read the stories. Upgrading has been put off because I only need them for pulling wheels off and work from the outside. Because of the reports here I won't crawl under the vehicle and endanger myself with them. I have for and I always double up leaving one a notch down if I can't get it to the same height. Well this weekend I was working on a car and got the passenger side up and "secured" went and started raising the drivers side and heard a pop and the car shook. The jacks looked ok so I got the drivers side secured and went over to check the passenger side.
Sure as **** the ratcheting arm was busted doesn't seem to be holding like its supposed to.
So no I am looking for recommendations on good quality safe jack stands.
in our shop. The cast sliding piece never had the ratchet pawls true enough to latch securely. I ground each groove out, and only use these on light weight, non critical applications, and avoid using em. This junk shouldn't be allowed in the U.S. With all of our government control, don't they have a law against this?
they used to be called "toothpaste" welds
