That thing is a joke. Virtually every safety mechanism is eliminated. Jackshaft openers are really not meant to be used on standard lift track. The reason is that you can't push a door down with a cable. Gravity must act on the door to make it go down. With standard lift track, initially there isn't much vertical force to make the door go down. Now there are ways to mask this, like pitching the horizontal tracks and using pusher springs, but there is still the question of what happens if the door comes down on something. With the RJO at least, the cable tension monitor will detect slack in the cables and cause the operator to reverse. In a setup like this, there is nothing that will cause the opener to reverse (the internal force adjustments mean nothing because there is no change in force as the opener continues to turn the shaft). That means you end up with a wad of cables and a door sitting on whatever it isn't supposed to.
I don't normally throw this out, but the guy that posted the video is an absolute idiot. It is bad enough if he were just to do it for himself, but to make a video and try and sell this BS to others is just ridiculous.
Please no one follow this guy's instruction!!
John
