Jacobs Chuck Wedge Sets
mwscale
Kansas City Area
On the Jacobs website they show all of the wedge sets have been discontinued. There are still some out there but who knows for how long?
Davefr
OR
IMHO they are worthless. I don't think I've ever had success using these silly things. It usually takes drilling a hole in the bottom of the chuck and punching out the arbor.
Provincial
Near Salem, OR
I have used them successfully. I've also drilled a hole, like Dave did, but a drill will work it's way up into the hole if the jaws slip. If the bit is a tight fit in the hole, it can try to friction weld itself together.
FrankLee
seMI, 48317
Yes, they can be stubborn sometimes.
I've had a couple where the previous owner used some kind of retaining compound to attach the chuck to the spindle. Those were impossible with wedges. I did have to drill one or two to save the spindle, but those chuck bodies were fubar. Once I used a torch on the naked chuck body to get it off the taper.
This one yesterday needed several good whacks. It did not have the thrust collar nut either. I had removed the quill/spindle assembly from the head casting first.
This one was easier.
Before the Jacobs Safe-Lock chucks were standard, wedges were generally included with the drill presses. I can't imagine using the wedges with the quill/spindle assembly still in the head frame.
