JCPenny Hand Drill Press Stand - Anyone still use these type things?
Marc Benjamin
Napa California
So I picked this up at an Estate sale to what comes out to be $5
I've always seen them and never bothered but yesterday I pick one up on a lark, perhaps.
The drills not bad. Not reversible but it locks. Maybe 1000-1500rpm and has that old brush electricity smell (not really burning wire/smoke smell) when turned on for a whiles.
I don't own a drill press (yet) and I haven't even really found a need to use one since I don't do woodworking or stuff where a handheld just won't do.
So I have this now and I was wondering if anyone else still uses (or did people ever) these and heck can I even buy a press table and/or vise for this?
SASORacing
Utah
If you dont have a drill press yet then good find, drill presses are a must in a shop. I wouldnt have a problem using my cordless m12 drill in that stand, looks fun.
Thumper68
Duluth MN
I have two of them, a CM and a no name, I use them in place of a mag drill when I need to drill holes in a piece that is to awkward or to big to use the DP on.
The CM one has a hole in the center of the foot, a couple of big clamps and you are set.
lakota
Western New York
The smell the OP mentioned is Ozone or O3. It a common smell around running electrical machinery.
Marc Benjamin
Napa California
back2class
I had one. Was free and was worth about $5. Maybe slightly better than you just holding the drill yourself, but if you have very very limited needs for drill press functions then it may work for you.
dutchgray
Dorset. England.
Oh I picked one of those up to at the same auction but the drill was DOA:
It's the one right next to the buffer on the left.
How would you use that? Just to make sure your drilling straight down on a flat?
Pretty much, on some you can extend the bars down through the base so you can tilt it over to an angle and some have a V grove in the base so you can drill the center of a pipe easily. They are useful when what your drilling is too big to get to a proper drill press.
zkling
I think you overpaid. Even the basic off shore drill press is miles ahead of those things.
larry_g
oregon
I also use one as a poor mans mag-base drill. The one I have holds my big old Sioux 1/2 or 5/8" drill motor.
lg
no neat sig line
monomach
Illinois
You can just make a wooden base to mount it to. Pretty nifty for making a perfect 45 (or any other) degree hole.
You can also use it horizontally on a wall or whatever, so it's worth having around just for that.
The chuck is part of it. With a chuck key, you can get the dead drill off.
bpjr
Florida east coast
I have an old beater similar to the jcpenny one but only used it once or twice with a 1/4" drill. This one has a large stainless band that holds the drill and I consider it a step up from just holding the drill. A cool and light weight tool to travel with in an RV or boat when a regular drill press can't go. I lived aboard and cruised a sailboat for 10+ yrs and it was the only "drill press" I had room for.
bp
orca8589
Concord, CA
I have a similar press, and it's great for small projects. So far I've been able to avoid having to buy a regular drill press, but I may eventually get one anyway.
~Chris
