Jet Belt/Disc Sander vs what?
Hustler388
I have a Craftsman table top style thats junk,a pain to use,I want some thing thats has a good stable plate on the belt and disc side, the Craftsman one moves all the time and want stay SQ to the sandpaper,
This is the newer version of what i got
http://www.searsoutlet.com/1-3-hp-B...d=1224&mode=buyUsedOnly&itemSelectionType=all
The Jet one seems pretty nice but alittle pricey at $676.00,
The Enco looks alittle on the cheaper side, and the ledge on the belt side is the same as the Craftsman. I assume its a china one also.
Grizzly 477.00 shipped, looks like the Enco
http://www.grizzly.com/products/G1014Z
Jet 676. prob plus shipping
http://www.amazon.com/dp/B000063INV/?tag=atomicindus08-20
Klutch,Northern tool same as above
http://www.northerntool.com/shop/tools/product_200621484_200621484
Do you all have any suggestions? advice etc
Thanks for any help:beer:
I dont mind spending over 300 but didnt want to go over 500
Rob
rsanter
visalia ca
The problem is you have the smaller bench top Cman unit. They have some older larger ones that are way better. I got mine for $50 and it works great.
They are worth $100 to $175 pending condition and they come available here and there.
The older delta, Rockwell, powermatic units are also great and worth popping $200 to $300 for one in good shape
Bob
tedsters
look around on C/L for an older 6x48 W/12 disk i picked one up for $200 put a new 2hp C/L baldor motor on it fresh paint, wire, power switch, belt and disk got around $350 in it get the 12 disk you will never look back
exmaxima
Consider what you want to use it for. Do you really need a wide belt? A wide belt is handy for woodworking, but if you mainly want to grind metals or plastic you should consider a 2x48 sander with or w/o a disc.
I had a Rockwell/Delta 6x48, then a 6x48 w/12" disc, and recently I sold them off---I found I use my 2x48 and 1x42 grinders much more often. If I was to add another grinder it would be a large disc---no wide belt.
That said, for woodworking it is hard to beat a Rockwell/Delta 6x48. Get at least 1HP, while 2 hp would not be overkill. I see them all the time for $200-300 (used of course).
