jib crane mounted to lift post?
chadman
Wakeman, OH
Has anyone ever done this? I am considering mounting a small jib crane from one of the posts on my 2 post Rotary lift. I would like it to swing away when not in use. It would basically just be an I beam with a small chainfall strictly for pulling motors. 750 lbs. max. Thoughts?
STINEY
Bucyrus Ohio
I would just use the lift itself to pull the motors.
You can buy or build an adapter to use both lift arms equally.....
scott37300
Wisconsin
How long of a beam are you wanting to make? I don't think I would put that kind load on the lift like that, it might be able to take it but I wouldn't do it personally. If your jib extends out very far it could put a lot of stress on the lift post. Also I don't think a jib would be the best setup for pulling an engine because you can't pull the engine straight out like you can with a cherry picker. You would be pulling towards the side of the vehicle since you jib is mounted on the side of the vehicle, be hard to pull the engine towards the front of the vehicle.
Personally I would make a setup that uses both posts of the lift and raises up and down by the lift. The only downside would be it won't swing or move in or out unless you make a trolley setup. A setup that mounts to your arms on both posts and has an I beam going forward with a trolley on it would work pretty good and I would think that would put less stress on the lift.
akdiesel
Wasilla, AK
Keep in mind these lifts are designed with a safety factor of probably 3-1, but with that said if you have the additional unknown weight of the beams on the main support post along with the vehicle on the lift you are at risk.
C
chadman
Wakeman, OH
The chainfall would enable it to lift straight up. I was figuring about a 6ft. I beam with the chainfall on a trolley. I guess I could just temporarily mount an I beam spanning across the lift pads. I was just looking for something more permanent that is self storing.
C
chadman
Wakeman, OH
I have no plans of using the crane with a vehicle on the lift.
gsport
Salem Oregon
for all that work, i'd just get a good cherry picker if you're just going to be pulling engines.. i've got a jib and a overhead crane and i still use my cherry picker for engine pulling...
BLUBAYOU
