zippy1981
Bought a never harbor freight 8" bench grinder for $25. Well worth the cheap cost. I turn it on, put metal objects against it and it removes metal. I do want to upgrade the wheels, and I'll follow this guide when I got the money and time:
http://www.ncwoodworker.net/forums/showthread.php?t=49738
I did buy one of those T-shaped diamond dressers for now to see if it will reduce the vibrations. Honestly though vibrations are pretty minimal. I'm sure as my skill grows I'll grow more annoyed at the slight imbalance.
Anyway, do I have any cheap or easy to fabricate options to replace the built in tools rests? Basically I'd like brackets that I could bolt a piece of flat stock to that goes across both wheels that bolts into the wheel guards like the current rests do. that I can adjust the distance to the wheel of as well as the angle. I'd like it it had a protractor. The wheel guards are aluminum, but I don't care the material. I could use nylon bushings and washers to prevent galvanic corrosion.
Before I go crazy fabricating this, did someone already do something similar I could buy? I just want something relatively true so I could reface chisels, redress drill bits and clamp jigs to with the confidence that it will be true enough.
Or do I really just need to get those tool holders that get clamped to the table next to the grinder?
