Jigsaw blades... ?
themiller
Seattle Suburbs
So the jigsaw seems to have fallen out of fashion lately with all of the new ways to cut, but I still find it very useful - likely because I haven't spent money on the new ways to cut...
I've found good blades for my sawzall, scrollsaw, circular saw, and miter saw - what I haven't ever found is a good blade for my jigsaws - mostly because I have never looked and because I was working my way through the unmarked tin of blades from the ?70s? my grandfather gave me. Finally killed my old hand me down, and the hand me down that replaced it - the one I have accepts universal or "T shank?" type blades.
Wondering what ya'll that still use these have found to work really well? I'd prefer to buy a variety pack of 25 blades and just be set for the next decade but I'm open to buying singles if there are "must have goto blades" from different manufactures. I pretty much exclusively cut wood - specifically varying grades of plywood and random patterns and notches in 2x4,6,8's to notch together who knows what depending on the project of the week.
neophyte
Pennsylvannia
For Jigsaw blades, the Swiss Made Bosch blades seem to have basically become the Worlds standard, or at least that’s what it looks in the USA.
I’m fairly certain most if not all jigsaw blades that you find that are labelled “Swiss Made”, are likely made by Bosch in a factory they own in the Italian section of Switzerland.
In addition to the Bosch branded blades, Skil jigsaw blades were also made in Switzerland, since Bosch owned Skil up until recently, and so were the Vermont American nlades, since Bosch also owns that brand. The Diablo brand is also owned by Bosch, so Diablo jigsaw blades are likely also Swiss Made in the same facility.
In addition to the above Bosch Owned brands,
Milwaukee and Makita jigsaw blades are also now Swiss Made, although in the past the Makita blades were Japanese Made, and the Milwaukee blades might have been US made.
A bunch of other Tool manufacturers also sell rebranded Bosch blades as well.
Basically, you can’t really ho wrong with the Bosch blades.
That said, Lennox and Irwin also sell jigsaw blades, and both may be made in the USA, at least nowadays, since both companies are now both owned by Stanley/Black&Decker.
Lennox is and was known for making quality Hacksaw, Reciprocating Saw, and Jigsaw blades so I don’t see Stanley shutting down that factory.
Stanley/B&D owns the Dewalt brand, so new Dewalt blades that are made in the USA are likely going to be made by Lennox.
Other Dewalt blades are sometimes made in Germany as well, although I’m not sure whether by B&D themselves, or whether they source the blades from an outside factory.
There are other US tooling suppliers that also sell jigsaw blades, but I’m not sure whether they just rebrand blades from Lennox, or whether they produce the blades themselves.
Starrett used to produce jigsaw blades in the USA, along with bandsaw and hacksaw blades, but I think the jigsaw blade production has been moved overseas, maybe to Brazil. The blades where supposedly good though I haven’t tried newer production.
Germany has two major producers of jigsaw blades from what I understand, MPS Sagen, and Wilpu.
MPS Sagen seems to manufacture a much wider variety of jigsaw blades than Wilpu, but both companies have a decent range.
One or both manufacturers also produce rebranded blades for other German tool suppliers, and Power Tool manufacturers, like Fein, Festool, and Metabo.
There is also a tooling supplier in the USA called Spyder that seems to rebrand a small number of specialty jigsaw blades made by MPS Sagen. The Spyder blades are available at Lowes and thru Grainger/Zoro among other suppliers.
There was also another brand in the US that slso seemed to be rebranding the blades from one or the other German manufacturer. Maybe D&N Tools or something like that, although I’m not absolutely sure the brand name.
In addition to the above, there was a French manufacturer that used the brand name “Ultra” that manufactured high quality Jigsaw, bandsaw, and hacksaw blades.
I think the company may have gotten shutdown, and the brand name sold, but if you find the French made blades, they should be quality, and there seems to be stock still around.
Another brand was Eclipse from the UK, which was known for their hacksaw blades.
They also manufacture jigsaw blades, but I’m not sure whether those are still British made, or whether the production has been outsourced to Bosch or other.
Basically though, if the jigsaw blades are Swiss or German or French, they should be decent quality.
There can be different quality levels within the jigsaw blades themselves though.
I think Bosch mostly uses Carbon steel for blades meant for regular wood.
Dewalt at one point seems to be manufacturing some jigsaw blades for wood out of a high speed steel steel like M2, although I’m not sure whether that is still the case. It wood help with durability though.
Blades for metal cutting are where some of the major differences are.
Bimetal blades are usually best for longer use.
High Speed Steel blades are also sold for some of the same cutting tasks, but will have a shorter life expectancy.
There are also carbide toothed blades for cutting laminate, Corian, Carbon Fiber, and materials like Stainless Steel, although the blades are pricey, and usually sold in single packs.
Otherwise, Bosch makes blades for cutting most materials, including several different types of specialty blades for different types of plastics.
JRC3
Southwestern OH
When I was 20 (1990) I worked in a cabinet shop and got introduced to the Bosch jigsaw after only knowing stuff like B&D and the like..So I always thought the Bosch jigsaw was like the top of the heap. Since then I always used their blades even though I had a Milwaukee version saw.
I would try Diablo too considering how awesome their recip and circ blades are.
engineer2
Chicago burbs
I had to cut some hardened steel with my jigsaw. Bosch blades were a total failure. My Makita blades worked very well.
MoonRise
Bosch 'precision' blades. With actual ground cutting teeth, as opposed to some stamped-out tooth shaped snaggles on a piece of butter-soft steel.
You still have to match the blade to the task. Tooth 'type' and TPI and purpose to the task. Don't use a fine tooth high TPI wood cutting blade for trying to cut steel, for example. :lol:
https://www.boschtools.com/us/en/boschtools-ocs/jig-saw-blades-22079-c/
AFAIK, Diablo is part of Freud, who is owned by Bosch. Skil was sold by Bosch (owner since 1996, previously owned by Emerson since 1979) to a Chinese owner, Chervon, in 2016. TTI (Hong Kong) owns Ryobi and Milwaukee and Rigid (and others).
https://toolguyd.com/tool-brands-corporate-affiliations/
Dave455
Sussex, England
Well, I live in rural Sussex, England. My nearest (small) town has at least 8 places selling jigsaw blades, each with a different range.
My view - the common Bosch blades are pretty decent. I can get crappier ones, but there’s not much saving, so I stick with what I know works. I’ll go with MoonRise above though, you need the right blade for the task, but for what they cost I keep a selection to hand!
I can get more expensive ones too (Festool come to mind) but when the Bosch do everything I need I’m reluctant to spend more. Maybe if I was using the thing professionally I’d notice a difference, but I can’t fault the quality of the cut, so I’m happy.
There are some power tool bits (drill bits for example) where the average ones seem to be pretty crappy, and I’ll willingly pay more for better. Jigsaw blades generally seem to be o.k. though.
I’m with the O.P. on this one though, Jigsaws are seriously useful, and quite under rated in my opinion. My Dad bought one when I was a kid (when they weren’t a common tool) and we used it on so many projects I wouldn’t be without one now! The only saw I probably use more now is my Bosch 12v mini circular saw, but that’s a relatively recent acquisition!
Jon_E
Southwestern Vermont
Have always bought Bosch blades. Home Depot near me recently clearanced all of their Bosch blades and I found out they replaced them with Diablo blades. Learning about the ownership chain in the comments above, I guess they're the same thing. I bought a decade's worth of the clearance blades though, so it will be a long time before I try anything else.
jgromada
Maryland (between DC & Balt)
Still think Bosch makes the best jig saw blades as well as the best jig saws. I think mostly Swiss made. These are U type
dnschmidt
Phoenix, AZ
Just for fun I'd like to point out that none of you are talking about Jigsaw blades, you're talking about saber saw blades. Jig saws are stationary tools used for scroll work. The are clamped on both ends and look nothing like a saber saw blade. Now, if you're talking saber saw blades I will agree with everybody else that Bosch is the way to go. They have always been the leader in making saber saws as well. Their pistol grip in a thing of beauty.
techieman33
Kansas
The stationary jig saw was called a jig saw instead of a scroll saw because the blade was only clamped to the tool on one end. Not two like a scroll saw.
For the portable saws it used to be that jigsaws had a rotating knob on top that would let you turn the blade. Saber saws did not. These days that feature is pretty much non existent. Jig saw and saber saw are interchangeable terms, but most people use jig saw. There may be some regions that still use the term saber saw, but I couldn't tell you the last time I heard saber saw used before reading this post today.
I think DN is correct if you go back a few decades. Nowadays, no one has a clue.
But now, if you google jigsaw, and ignore the movie that comes up first, lots of images of saber saws now being called jigsaws.
LeeG
Phoenix, AZ
Some interesting links of the Jigsaw/Sabre saw discussion for those interested. For a long time, sabre saw and jigsaw were used interchangeably.
From the first link below:
This 1977 quote sums it up perfectly: “For one thing, with a scroll saw (sometimes called a jigsaw) you will be able to do all the curved and intricate sawing you would like to be able to do with a saber saw (sometimes also called a jigsaw), but can’t.”
http://www.props.eric-hart.com/features/saber-saw-vs-jig-saw/
https://www.thesawguy.com/sabre-saw-vs-jigsaw/
T
themiller
Seattle Suburbs
OP back in the thread - thanks everyone! And interesting tidbit about sabre saw/jigsaw/scroll saw. My Grandpa used to tell me to get the saber saw :) Many that was a heavy all metal son of a gun.
I 100% would not have gotten Bosch blades, really great history and ownership. Ya'll are awesome. For now I think I'll circulate that chart for Christmas to answer the never ending questions from relatives of what I want. Hopefully I'll post up on New Years and we'll see how many I got...
johnnyradiant
Vancouver, BC
Like so many other words in the English language the meanings can evolve over time. But a little bit of research suggests the jigsaw-sabre saw debate here is only partly right. The jigsaw apparently came about when some guy was monkeying with his wife's toys - he stuck a saw blade into his wife's sewing machine in 1946. It started as a stationary tool but my oldest jigsaw dating back to the mid to late 50's already had the nameplate state it was a jigsaw. The below article states the sabre saw was a bigger, not as accurate or intricate, brother to the hand tool version jigsaw. It's what we know today as the reciprocating saw.
Either way if you want one of them blades with a 't-shank' or the more straight shank with 1 or 2 little holes in known as a 'universal' you'll need to be adopting the modern English language name that all the manufacture's refer to as a jigsaw blade.
Jigsaw - Sabresaw
txvwnut
Bedford, Texas
I'm on my fourth jigsaw and still have some blades I bought back in the eighties. Tells you how much I use a jigsaw. But I also have some Bosch blades mixed in and they are so much better than the blades I've had for years, and the old ones are still in the wrappers.
