Jigsaw??
tikiboi13
SAN PEDRO
A fellas another question for u pros out there. U guys know everything. I am going to use thin gauge metal for my interior panels on my chevy and was wondering the right tool to use to cut it? I was thinking a jigsaw? Wanted to see what u recommend? Thanks for all of your guys help.
84TurboBuick
Illinois
Air shears (or snips if your really good with them) would probably work better, or a large throat band-saw if you have one.
The problem with a jigsaw and really thin material is the vibration caused may make you miss cut it... that and the edges will be jagged.
Bolster
Mexifornia
Ditto above.
If you decide to use a jigsaw because you don't want to buy new tools, then back your metal to a thin sheet of plywood before cutting, that will help. And get a fine tooth blade for your saw, remembering that 2-3 teeth should be engaged in the work at any time. But, a jigsaw is not the ideal tool here, it is merely the expedient one.
Hey Tiki, welcome to the board. I see you are a so cal neighbor.
metal1313
clinton NJ
with the finest blade you can get, using the saw at a low speed and not pushing it to hard you'll be fine. id think about rubber cementing the metal to some heavy cardboard or luan or something else to make cutting a little easier, then you can peel it off. when your done just file/sand the edges
now if you want, id say if you can get yourself a little electric nibbler or hand shear.
like this one, http://www.toolbarn.com/milwaukee-6852-20.html , or really cheap http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92148
