jimgood
I have wanted a welding table for at least two years now so it's finally time to start on it. I decided on a slat style top using 1 x 4 x 36 cold roll slats mounted on C3 x 5 channel. I would love to do a CAD design first but I can't stand the tedium of trying to learn the available tools. I've tried several and all that happens is I get pissed off after two minutes of trying to translate my layman's understanding of what I want into enginerding terms.
I had originally planned on a 3' x 5' top so I ordered the 1 x 4s cut to 36" and the channel cut to 60". But, when I tried to fit my clamps a 1" gap between two slats, that all went to hell (I'll get to that shortly).
I don't want holes in the top. The plan is to drill a pair of holes about a half inch deep under each end of the slats. I'll use all-thread in the holes with nuts for locking and height adjustment. I decided on about 6" of overhang so the holes will be 24" OC.
Here I'm just laying things out to see where I am. Channel on saw horses with one slat for reference.
View media item 79716
Structural channel has an angle in the web. I bought tapered washers to compensate for that so that the nuts on the underside will set flat. These washers are cast so they're pretty rough. I have radiused the thin edge to allow them to fit as far under as possible (see next pic).
View media item 79717
Here you can see that the radiused edge of the washer allows it to fit better. It's actually pushed in a c-hair too far but you get the idea.
View media item 79718
Next, I needed to know where to mark a line for drilling the holes. I positioned the washer while holding a straight edge where the washer ends. I marked a vertical line on the end of the channel that could then be transferred to the top.
View media item 79719
I used this deal to transfer the mark from the end to the top.
View media item 79720
Now I have a reference line so I can position the washer and use a transfer punch to mark the hole center.
View media item 79721
Then I set up the slide rule to match up with the punch mark and used it to scribe a line the length of the channel. Hmmm...I need to remember to check this to ensure the channel is straight because I'm using the edge as a reference, which might NOT be straight. I think a reasonable tolerance will be 1/32 +/-. Any more and the holes will have to be drilled bigger than 1/2".
View media item 79722
Next, I wanted to see if my planned 1" spacing would work with my collection of C-clamps. Negatory!
View media item 79723
The black clamps are really bad in that the clamp actually tilts backward as it starts to clamp. The result is that I will need 1 5/8" gap. I suppose this could be workable but it means I have to rethink the number of slats. 9 slats comes out to 59 5/8". I might be able to squeeze in one more slat, depending on how I position and space the mounting bolts. I need to meditate on that for a spell.
View media item 79724
View media item 79726
