Joining two baseboard heaters
krisway
Newfoundland, CA
I have a base board heater in my garage, and would like to add a second one. The wires are in my attic, is it okay to use a junction box and tie in my second heater? OR, do I have to join the heaters end to end? I want the heaters on opposite walls, and would like to be efficient in running wire.
If the two heaters are 2000w each, is 12/2 wire okay, hooked up to a 30 amp double pole breaker? Or do I need 10/2 wire?
VHF
NW Wisconsin
2000W/240V = 8.3A
8.3A x 2 = 16.6A
#12 wire must be on a 20A (or smaller) breaker. For a continuous load, the rule is that connected load should not exceed 80% of of the breaker. 20A * 80% = 16A. So unfortunatly, you are just over the permissible continuous load for a 20A breaker with 12/2 wire.
A 30A breaker allows up to 24A continuous, but requries #10 (or larger wire).
So either put both your heaters on a 30A breaker using 10/2 wire, or put then each on their own 20A breaker using 12/2 wire. Don't forget to recolor the white conductor to red for the second hot leg in a 240V application.
Doesn't matter if they are joined end-to-end or at a junction box in the attic, but if using a 30A breaker the entire circuit must be #10 wire.
If it wasn't a continuous load like electric heat or lights (or if you heaters were slightly smaller) then you could put both an a single 20A 240V circuit wired with 12/2.
Addendum--Check for a data plate on your heaters. If it lists current as 8A (not 8.3A), then you would be OK putting them both on a single 20A circuit wired with 12/2.
K
krisway
Newfoundland, CA
2000W/240V = 8.3A
8.3A x 2 = 16.6A
Thank you for your answer. I will run 10/2 wire from the 30amp breaker to both 2000 watt heaters and have the heaters joined using a junction box in the attic.
If I'm heating my 16x36 garage at 10 degrees for the winter months, would this be considered continuos load?
pattenp
Virginia - USA
Yes. Continuous load is where the full current could be expected to run for 3hrs or more.
