Vintage Veloce
OK, so I admit this isn't about my garage... but you guys are such a a good resource I can't resist.
Our house was built in 1926 and we are having the chimney re-pointed (replacing the exterior mortar between the bricks).
Apparently, the original build just had mortar between the chimney and the redwood siding of the house. At this point the chimney is fully lined, and is setup as a gas fireplace so there is no real fire concern.
The mason suggests just filling this gap back up with mortar. Obviously, that will crack. I'd love to put something flexible between the mortar and the redwood clapboard, but I can't really imagine anything that will work. Here in San Diego, rain isn't much of a problem, and it has been fine for 90 years, so I guess I should just mortar it back up!
But are there any other great ideas?
Maybe, after the mortar is done, some kind of finish trim board, stepped to match the clapboard? I could caulk that to the clapboard siding and the brick. But the brick curves, so that's a problem.
