Junction box covers
bluedog225
Texas
I’m obviously no electrician. Am I thinking wrong or should this cover fit on this junction box? I can probably make it fit but I feel like I don’t understand something basic. Any thoughts appreciated.
u2slow
BC
That box looks like it's tweaked slightly into a diamond shape. They are supposed to fit together.
T444e
It looks like you have a 4" cover and a 4-11/16" box. If so, the cover will not, and not meant to fit that box.
carlaisle
Bottom left ear in the pic looks like it's bent in a solid 1/8" more than it should be. Use pliers or a crescent wrench to bend it back to where it belongs and everything should line up. Top right ear might also be bent in too far - hard to tell from the pic.
racecougar
Missouri
Not a sparky, but I have stayed at the HI Express before. You have a junction box and a switch cover. They don't go together and they are not supposed to. You need to go get a switch box and a junction box cover, then you'll have 2 usable boxes.
Sarcasm? Dry humor?
manwithtools
Lebanon, TN
You should ask for a refund from Holiday Inn Express. That box and cover are certainly made to work with one another. ;)
manwithtools
Lebanon, TN
This is what @sparky 1971 and @wyliesdiesels like to recommend, right?
But then you have to use a standard wall plate cover that will overhang the box, looks silly in surface mount application and provides a edge to catch things (like fingers) on. The 4" square surface covers mount flush to the junction box edges. I prefer to use a 4" drawn box with round corners, matches the cover even better.
Might want to take a look at pages 7-14 in this document: Steel city Boxes and Covers Seems like the manufacturer intends for that style of cover to work with a 4 Square box.
mike93lx
Richmond, VA
Wait til they respond and you'll get why I added the emoji
finn
The UP, God's country
Get a 4” box. Spend a few minutes in the electrical aisle and you’ll figure it out,
The box you have is a junction box, not an outlet box.
It’s not tweaked, it’s just that your photo is out of place, and thus distorted.
sparky 1971
Central Iowa
sparky 1971
Central Iowa
There are covers for handy boxes. Switch, decorator, single and duplex receptacle, and blank.
sparky 1971
Central Iowa
It should fit unless there is something wrong with the box. It happens, yesterday I bent the side of a box in about 3/4" just trying to get a factory knockout punched out. Everythingbis junk these days.
Those should work together, something is wrong with the box.
Not a 4-11/16. They have a goofy screw pattern.
sparky 1971
Central Iowa
I'll be a better person, but have to ask... Be honest, how many of these are on your truck?
Of those, zero. I only use them as a splice box for the sensors for overhead doors when I wire pole barns and shops with exposed conduit. I do try to keep one 2-1/8 deep handy box for the once in a while time a 4" square box won't fit where I need it to. And I have zero use for the standard 1-7/8 deep not so handy box.
manwithtools
Lebanon, TN
Great. Thanks all. I had two boxes and they were both off. I worked it and they both can take the cover.
Did you happen to miss the post (#16) from the OP where after straightening the box, the covers work just fine? ;)
The boxes were clearly tweaked. It is a 4" box and a 4" cover and they will work just fine together as the OP reported.
BrandonV
Arizona
I despise the name "handy box". I instantly picture 8.5 cubic inches of hell surface mounted while in reality the thing in the package is a 2-1/8 inch new work deep box with a stud bracket.
sparky 1971
Central Iowa
There are 2-1/8 deep surface mounted handy boxes, those are the only kind I will use if I have to use one for a device. The standard handy boxes that people get scolded for are 1-7/8 deep. I was going to take a picture, but I don't have one on my truck. Then I was going to post a link but my copy and paste won't work. Google Raco 8670.
BrandonV
Arizona
I saw a work order once that specified a bunch of RACO 671s... not quite what I would call a "handy box" but I guess RACO had a different idea. To me a "handy box" was always a surface mount box with absolute **** volume.
Honestly if people would just use 4S boxes everywhere...
u2slow
BC
Never heard "handy box" until GJ.
1110 box (eleven-ten) for the rest of us.
