Junction boxes without ground bump
bluedog225
Texas
I ended up with a bunch of steel city junction boxes without ground bumps. I’m going to mount them on a concrete wall. Are grounding clips the way to go or should I drill and tap? Or it doesn’t matter?
Thanks
mm08822
Recycle all ground clips........they ****.
The smaller hole in the back of the box may already be threaded unless they are super old.
You could tap them all before installing just to get it done.
May want a pilot hole on the wall behind screw hole for screw clearance so you aren't fighting with the screw/concrete.
bluedog225
Texas
Ground clips meet the code and you can use them but they ****…….. Just drill a 1/4”x1/4” deep hole in the wall to accommodate the ground screw where it pokes through the box.
BTW! I have never seen a junction box without a threaded ground screw hole.
Ok. No ground clips. Good to know.
They all have threaded holes. I was just trying to figure out whether it was easier to tap a new hole in the side. Though a 1/4” hole in the wall wouldn’t be a big deal. There are only 16 boxes I need to do.
Thanks
JohnX14
Boston 'burbs
I'd drill a 1/4" hole as others suggested for the ground screw. Nothing wrong with using the emt as a ground, but I'd run a grounding conductor.
Chuckster in NJ
Hunterdon County NJ
Now you have.
I assumed the OP was referring to modern equipment. :beer:
Well preserved example of a 1950’s ceiling box when they didn’t use ground wires.…….. I saw these used in post war homes where they used 2 wire Romex with that "silver cloth like" jacket OR where they used BX.
Grounding of boxes became "code" in 1962.
WARNING! Make sure you are up to date with your tetanus shot before you handle this rusty antique box that came out of a Newark, NJ demo site. (y)🤠(y)
mm08822
Never used. This is NOS for certain.
Was purchased post '54 by my dad for his new (then) house to finish the basement. All bx in house, snap switches, 2-prong recepts, porcelain lamp holders, Wadsworth split-buss 60A fuse panel.
I never used it b/c I was too lazy to notch the joists so the rock sat flat.
35Ford
Central MA
I agree with the others, skip the ground clips. A 1/4" hole in the block is probably the best option. In a pinch, put a 10/32 nut on the ground screw before you thread it into the box. With the nut and a ground wire under it, the ground screw will barely protrude past the back of the box.
bluedog225
Texas
Got it. Lots of good options. I‘m guessing a little bolt and nut through the side is also acceptable. I could crank those out pretty quick.
