just applied floor coating have a bad feeling
dabears77
I just applied epoxy garage floor coating and everything went well. That is up until the last section. There was a 3"x 3" spot that when i back rolled would come off. It has to be some kind of grease or oil that I missed. I just covered it because it was a little to late to do anything else. Is there any chance that this small spot won't peel? I did put the flakes on pretty heavy through the whole floor and even heavier on that spot.
Shea
California
That amount of flakes that are put down on the coating doesn't have anything to do with how well the epoxy will adhere. You won't know how bad it might be until it cures. Doesn't sound promising...
bigbadktm
SoCal
Nope doesn't sound good. What type of prep did you do, and how did you clean up any dust?
D
dabears77
I spot checked for grease and oill spots cleaned them with mineral spirits. Then I cleaned entire floor with the etch that came with the kit; scubbing the floor in both directions and once during first rinse. After each section was etched and rinsed I rinsed entire floor two more time and squeegeed floor dry. I waited two days before applying coating. Its just the one spot that has me worried. If after curing and it looks and feels ok should I just let it go and hope that spot dont start peeling?
rugerlady
You may eventually have a lifting issue. If the epoxy wouldn't lay down, the chances of a contaminant are pretty good. Is this spot in a a heavily traveled area?
D
dabears77
Its about a foot in from the garage door so it should be safe from vehicle traffic.
D
dabears77
I will post pics tomorrow. The floor looks great if it wasn't for that one spot I would be totally at ease. Time will tell.
