redmondjp
11.5 @ 40 psi and 11 @ 90 psi don't make sense either
Why not?
It's a two-stage pump and the flow numbers don't drop off until much higher pressures.
If it was a single-stage pump, then yes, they wouldn't make sense.
And despite the claimed 7.4 CFM @ 90 rating on the $800 Quincy I can't use a die grinder for more than 20 seconds on a full tank. And if I keep running the grinder it will run the motor forever and the grinder just keep running slower and slower. And just forget about the sand blaster.
Are you talking about the pipe thread (NPT) reducing bushing that is threaded into the tank outlet? They are commonly available, just search for your pipe sizes such as 2" male to 3/4" female. Good luck getting the existing bushing loose from the tank!I am looking to change the port from 1/2" to 3/4". I have not been able to find one. Does anyone have a link?
