I just completed applying epoxy to my floor. I used Epoxy-Coat. I called Christine and she shipped it to me for free. As you can see, I used a gray base coat with blue-black-white flakes and then applied a clear top coat.
Prior to applying the epoxy, I cleaned the floor as good as possible, and then I used the Phosphoric acid powder that you mix with water (this came in the kit). As far as I'm concerned, this acid is a total waste of time. First - I could not get it to dilute very well, and so it would clog my hand sprayer. In addition, I tried applying it as thick as possible, but it would not etch well. So, after trying to etch the entire floor with this method, I purchased some Muriatic acid, and mixed it with 2 parts of water. I put this on very heavy (on a damp floor) and it worked very well. I rinsed really well and then neutralized everything with a soda wash and a lot of pressure wash rinsing.
Next, I put screen spline (rubber string) into my expansion saw cuts, and then put latex epoxy (concrete colored stuff from ACE Hardware) in the joints. I was really happy with that stuff, as my seams look really nice.
Finally, I applied the base epoxy, the chips and then the top coat. During this process, I ran into two problems. First - I was not able to apply it fast enough (really a 2 person job), so there are a bunch of areas where I rolled it when it was setting up and it has a nap in those areas. Second - I have lots of small (very small) fisheyes in the finish, all over the floor. I really think that the floor was VERY clean, so I am a bit disappointed they showed up, but no one (but me) has noticed them, so it probably isn't a bit deal.
Overall, I'm really happy with it, and looking forward to finishing the trim work. I've got pics of my project on "New 40x60 colonial" in the garage gallery.
