Just ordered Delta Dye samples for a possible outdoor patio project.
Carnut12
Good Evening,
I just ordered Slate Blue, Cola, Brown, and Grey Delta Dye samples from Legacy. I added pictures to show the areas, one is a screened in porch with a small area outside the screen that will have to be done, the other is a patio on the carriage house.
I was thinking browns with blue might look cool.
Quick questions-
1. Will this make the concrete easier to clean, I’m assuming the clear will level some of the roughness and make it easier to sweep/clean.
2. Any thoughts on the small strip outside the screened in area? Will that be difficult or easy after the prep?
3. I plan to pressure wash both areas and then allow them to thoroughly dry, other then that I’m assuming I’m fine because it is brushed and only 2 years old?
4. If all of the clay stains don’t come up can I just go right over it?
Thank you I’ll update everyone along the way.
LegacyIndustrial
deerfield, IL
Here are my thoughts…
We just stained a floor with TN clay stains. It added a nice bit of accent color. Etch smooth concrete. Rough, broom textured exterior concrete can be pressure washed, ok to etch if you have already. Once sealed it will be a little bit smoother and will be easier to keep clean for sure..
C
Carnut12
Thank you!!
