quadrcr87
I have been wanting to try Kaizen foam for a while and with the quarantine in place I finally pulled the trigger.
The focus was on a portable 4 drawer Craftsman Rally Box that I will take to the motocross track and off-road trips in addition to my 168 pc Husky blow molded case. The Husky box covers the basic ratchets and sockets but didn’t include some key items like a hammer, file, pliers, tape measure, etc. I was also able to incorporate some specialty tools like snap ring pliers, spark plug socket, safety wire pliers and even tire levers.
I went with the Fastcap 30mm black foam, Kaizen foam knife and long nose marker. I think Fastcap makes a great product and is leading the market.
I sketched out a layout to best use the 2’x4’ sheet. I even have some left over to do a tool drawer in my office.
I placed all of the tools I needed in the box and determined the most efficient layout. I would say I focused more on fitment than placing like items together.
After I had a rough layout plan I pulled each drawer out of the toolbox and did all my tracing, cutting and fitting on the bench. This was also a great opportunity to grease the friction drawer slides.
After I had all the tools fitted in place I heated up a 1/2” piece of tubing with a MAP torch and carefully melted in some finger holes. I intentionally made the tools fit tight as this box is going to be bouncing around in my truck and trailer a lot.
On to the finished drawers!
I went double layer on some of the pliers due to space limits. I put the smallest plier on the bottom. Both levels are a tight fit.
The top of the box required some thought. First I had to make clearances for the locking mechanism and shelf hinges. Then I needed to consider the cantilever shelf and the clearance it needs when closed. With the 30mm foam there is not much space below the shelf so I needed a layout that still allowed access to the tools. I left the top shelf without foam as it is mostly tapes and misc supplies.
The finished project
