Kalamazoo 1 SM sander
Jolomite
Detroit, Michigan
Not a terribly vintage item, though I hope the level of wear makes it permissible here. This is a small Kalamazoo sander that I polished up. Bought it for $65 or $70 at the flea market. The switch was cracked off inside the body, so I had to replace that. The original platen was looking pretty worn, so I made a new one out of bed frame.
In the third pic, you can see how I made one to roughly the same dimensions of the original. I installed that and felt that the platen was short, or rather too low for me to lean in and see finer work I'd want to do. So, a made a longer platen, with the top inch narrowed to the width of the belt for getting into corners and such.
This machine has a much lower sfm/ rpm than my old Craftsman Taiwan 1X42 sander. So far that has not hindered working on anything. I like the 1x42 size for sharpening drills, doing rough shaping/ sharpening of larger knives and tools. I also find this handy for small wood projects, like fitting new handles to chisels. I must say that my Craftsman 1x42 is really nice because you can rotate the position of the belt from vertical to horizontal. You'd be spending over $400 for a Kalamazoo that can do that. For as spindly as I thought this model looks, it actually feels quite solid in use.
  • Like
Reactions: RTM
exmaxima1
Midwest
I've owned a number of Kalamazoo belt sanders and don't like the slow SFM of the smaller 1x42 models. I also modified my platen and table but made it more versatile for steeper angles such as for sharpening. More details are here:
J
Jolomite
Detroit, Michigan
Thank you for the post, Exmaxima1. That is a nice design to incorporate the rest onto the platen. I think I will do the same. Did you use alloy/ hardened steel for those parts?
The rubber boot over the switch seems like a no brainer as well. The broken switch I replaced did show signs of having cooked pretty hot at one time. I'm sure foreign matter in the switch only makes that more likely. Does that switch cover/ covered switch have a particular name?
