- Location
- Clayton, NC
- Price
- 1400.00
KaTool KT-830
I purchased this KT-830 a couple of months ago. I am very impressed with the quality. I had no problem changing wide, low-profile tires with the double-assist arms. It takes some practice to get good at it, though. I bought this from a guy who had it in his home shop but was going through a divorce, unfortunately. He had only changed some motorcycle tires with it, and it shows. The machine looks new, except for some paint worn off at the bead break area, where the tires rub against it a little. I made a small custom shelf that is bolted to the swing arm tower for some storage. I came across a very nice used Hunter a week or so ago, which is the reason I am selling.
I tell you what, if I had the room, I'd keep this one set up for motorcycle tires. This will come with the KaTool motorcycle wheel adapters. If you live within driving distance of central NC, you can save some money vs buying a new one. The shipping, taxes, and residential delivery fees add up. There are several Youtube review videos out there.
Features:
Katool Automotive Equipment delivers professional shop tools that balance durability, performance, and value. The Katool T830 Tire Changer is engineered to provide dependable, efficient service day after day—helping your shop perform at its best.
Features:
| Max Wheel Diameter: | 41"/1040mm |
| Max Wheel Width: | 15"/380mm |
| Outside Clamp: | 12"-22" |
| Inside Clamp: | 14"-24" |
| Power Supply: | 110V 1PH |
| Motor Power: | 2.0HP/1.5KW |
| Rotation Speed: | 6.8r/min |
| Air Pressure: | 0.8-1.0Mpa (116-145psi) |
| Net weight: | 240KG/529lbs |
