Kaz's Random Projects
m5hor
how much are these? great work!
jlenander
Queen Creek, AZ
Hi Kaz,
Congrats on the new mill...looks like the start of a new adventure.
You built your first plasma table and used it (quite effectively!) for a long time. I think I read you're considering building another at sometime in the future.
When you get a chance, I'm really interested in hearing about what you liked and didn't like about your old table. What changes/improvements do you want in a new table? What would you do the same? What would you do differently?
Your shop looks amazing....I don't know how you have the time with two kiddos!
Thanks,
Jon
K
kazlx
Tustin, CA
Hi Kaz,
Thanks,
Jon
Thanks, I 'may' build another 4x4 at some point, we'll see. The mill is going in the garage, essentially replacing the plasma. I like sharing the shop, but it's about 10-15 min away and I don't get there as much as I like. It's nice having some things at home, so I can be with the family and still get things done. That is the nice part about CNC.
Overall the table runs really well. I'd probably lower the height of the next one, as well as make sure it's a version where the rails are lower than the material plane. That would help with loading and unloading material and parts. I'd also figure out a better setup for the water table, maybe side guards or something that can be removed. My biggest complaint about plasma is it's messy, especially with a water table. Compressed air at 80psi and water just make a mess.
Also, unless you have a full shop, IMO, a 4x8 table or bigger is overkill. It takes up quite a bit of the garage. If I had a huge shop or separate building on my property with a forklift, different story. It's pretty unruly to handle 4x8+ sheets of anything, so it's really not worth it. My routine basically became buying 4x10s and getting them sheared to 4x5. Even 14 gauge is still kind of awkward.
K
kazlx
Tustin, CA
Finally caught a long term grail tool. Really wanted a 20" but this 16" was just too clean to pass up!
Duker
Livingston, TX
Nice score..... !
I was bidding on one at an auction recently and I got outbid and I kick myself as even spending a few hundred more it would have been about 1/4 of retail.
K
kazlx
Tustin, CA
Yes, it wasn't cheap ($875), but it's also the cleanest original one I've ever seen, plus came with 25 papers of various grits. All the knobs are there, everything works, and has the original paint on everything. Love it.
But I also unloaded some other stuff that I haven't used, so it pretty much evened out....
slodat
Central-ish, WA
I have a late 70's import clone of the Apex 20" in really good condition. I have about $750 in it including the VFD. It's an amazing machine. Congrats!!
K
kazlx
Tustin, CA
Oh yeah, time for a bigger garage. lol
I actually sold the plasma table, so I'm going to have more room. This is about half the size, plus I was able to put it in a better spot, so it opens up the whole wall that the plasma took up.
Plasma hasn't been picked up yet, so it's super cramped right now, but workable. May end up building a small plasma table.
K
kazlx
Tustin, CA
There's those days that you just feel like the man. Imported logo as dxf to Fusion360, generated toolpath for .005 deep engraving with a 1/4 ball (only tool/holder combo I have right now that works until I order collets), changed the offsets, loaded the program and went. Super stoked. Plus I had my 3 year old out with me typing in manual tool changes and starting the spindle. A new chapter for me.
stioc
SoCal
Man, now that right there is beyond awesome. What are your plans for it? do you already have some projects in mind?
NASTYZEN
St-Colomban,Que. Canada
Congrats on your move to cnc machining and nice machine.:thumbup: Enclosed is really the way to go. Just to be clear about this KAZ, be careful with cnc, it's really addictive and can lead to serious spending on accessories!
Cool to get your son started early. I did with mine and now they work with me part time. Cheap labor.
K
kazlx
Tustin, CA
That ship sailed a while ago with manual machining :evil::rocker:
K
kazlx
Tustin, CA
I also scored some stuff the other day. Found a tumbler on CL for $25. Needs some love, but not too bad. Prob strip it and fix some stuff and use it. Media alone is probably couple hundred bucks.
I also bid on some stuff at an auction, tooling for a hone that my buddy has. Well, they ended up combining lots, and I ended up with all the tooling, another Sunnen hone and a die filer for $200.
Duker
Livingston, TX
I think I have to throw out a well deserved "you ****" on that score.... that's on top on the very nice new Kurts you have!
Sent from my iPad using Tapatalk Pro
K
kazlx
Tustin, CA
Freakin' love it. First actual part on the cnc. My dad needs some extended Y plates for his X carve. Just kind of stumbled through doing all of this myself. Got the programming done, loaded tools, set offsets and went for it. So much awesome. I need to fidget with some stuff before I make more and think I'll make the actual set a little taller, but really happy with my first actual start to finish part. It will go in my drawer of accomplishments.
And scored an Atago refractometer for $40 on ebay (for checking coolant concentration).
stioc
SoCal
Nice work man! that's an awesome machine. How do you load the g-code into it?
I had to look up x-carve, seems like everyone's getting into CNC in one form or another, from Arduino based Dremel CNC kits to the big boy toys and everything in between.
K
kazlx
Tustin, CA
I'm running a Windows 8 laptop with a program called DNC4U. G code is effectively just a text file, so basically just open up the program, call up the file, tell the machine you are going to send it and hit send. It works through a serial port. I just have a USB/serial cable the guy gave me when I bought the machine. I am looking into some other options just to streamline things. I'm already hooked. We can make some stuff if you ever want to. It seems overwhelming at first, but after a few days, it's pretty easy.
stioc
SoCal
Oh ok, that explains it exactly what I was curious about. I'd love to check it out one of these days and see it in action.
K
kazlx
Tustin, CA
First actual parts off the mill. My dad has an X Carve. Made some extended Y plates to raise up the gantry for more Z clearance.
stioc
SoCal
That's awesome man! I'm sure it's not even a comparison how much longer that would've taken on a manual mill? When it comes to pumping out many of the same part you just can't beat CNC.
K
kazlx
Tustin, CA
I need a sub plate to raise the vises up. I think the machine was originally set up for a 4th, since it has all the wiring. So I started on that the other day. Really the last thing I need to start actually working on some stuff.
stioc
SoCal
I'm liking the sub plate. I bet your mill is feeling lonely in the garage without a CNC lathe though :p
texasranger
Maryland
I shouldn't have looked at your thread. Not only did you build your own plasma table, now you have a CNC mill. Exactly what I've been wanting to do for years. Thank you for the inspiration that it's in the realm of possibility even with kids!
stioc
SoCal
Haha! btw how long did it take to slice through that aluminum brick on that bandsaw? Does it have a hydraulic feed or a spring? and what blade are you using 14tpi?
I need to get a better blade and a better feed mechanism for my HF 7x bandsaw that I bought over a decade ago but never got it to cut square or fast.
K
kazlx
Tustin, CA
I think it was 10 min or so. I have a pretty coarse blade on it. Maybe 8tpi or so. It's a hydraulic downfeed. It's a big saw, 10x18. It could use a new blade though.
