Still relevant to some (me, for example
) - I first bought a 20' container, had to keep the door open and a fan on (sorta defeated the original security reasons) - built a steel/fiberglass roof over it - between that and a few trees, NO PART of it sees the sun. Walk inside on a 90 degree day, temp does NOT CHANGE from inside to outside...
I now have 2 standard 40's and 2 "Hi-Cube" 40's - the hi-cubes still need moved into their "final resting place" and will eventually get a slab poured next to 'em and a 48x60 pole barn. They will be set side by side, one will be weld shop with built-in bridge crane, other will be a "tool room", leaving a 30x60 slab area for equipment maintenance/repair -
until I can afford the slab and building,, I'm thinking about getting one of these
http://www.greenhousemegastore.com/product/greenhouse-ventilation-package/greenhouse-exhaust-fans
in the 16"/24" size. Only pulls 1 amp on 120 volts -
IF that works as well as I think it will, I'll get 3 more for the other containers. Plan is to cut fan hole at the closed end near ceiling, and the louver hole at opposite end (with a welded cage around it - security thang again, one "neighbor" family is a couple notches BELOW trailer trash level)
The other day I took the IR gun inside the 40's, outside temp around 75 - inside, the ceilings were 130-140, walls 120 on the "sunny side", 110 on the shaded sides; bit more than comfortable, even for just raw storage.
Here's a shot of the small container roof; then the (still to be moved) hi-cubes - the two standards (one end visible) are end to end 12' from south side of existing (wood)shop, will get a lean-to roof from shop when funds allow. May take awhile, so the ventilation packages are kind of a desperation move. Last pic is where the 2 hi-cubes will go (the old trailer and other stuff is now elsewhere) ...Steve
